That's exactly what it is...or at least the object avoidance facet of the larger system. See the FCMB presentation linky on the last page; it's got illustrations.I feel like an on-board radar based emergency break system, such as those found standard in an entry-level Corolla since 2017, would make more sense for the surface lines than a track-side system, but Im no high-priced consultant.
By policy, you can't -- speed limit for that section is 10MPH. But as a matter of physics and engineering, you certainly can go at that speed. Clearly not a safe speed for the conditions, but nevertheless possible.![]()
NTSB: Green Line trolley involved in crash that hospitalized 27 was traveling 3 times the speed limit - Boston News, Weather, Sports | WHDH 7News
BOSTON (WHDH) - Federal investigators arrived in Boston over the weekend to help figure out what caused Friday’s crash on the Green Line.According to the<a class="excerpt-read-more"...whdh.com
The trolley that hit was going 30 mph. I didn't even know you could get that high on the B line.
The system that helps stop train collisions should be installed on the Green Line ASAP. There is just no damn excuse for this to just keep on happening & nothing is ever done about it. While other lines may have an accident only once in a while, the Green Line is very notorious for having such crashes. Let's put the blame where it belongs - on the T for not having safety measures put in place to make the Green Line safer.![]()
The newest ones have cams/sensors and a warning light/buzzer in the driver's line-of-sight for detecting pedestrians crossing in front.Do buses have a system in place?
How to apply to the T for an analytical job as a covid-era engineering grad?
DM me if it is too sensitive, but my daughter will be a 2021 UVa grad and has heard from Sound Transit (Seattle) and Tri-Met (Portland OR) but has found MBTA unresponsive.
No...the crash management profiles of the two makes aren't much different. The difference in damage profiles is almost entirely the result of one train having its brakes fully engaged while the other didn't.
There has been something wrong with the signals exiting Tufts Medical Center toward Back Bay for years. Trains have the brakes come on multiple times and jerk to a stop as an operator tries to leave the station. Happens virtually every train. No clue why the T cannot fix the issue.
I can confirm that this is still happening as of Wednesday afternoon. I thought I had remembered reading somebody on here talking about it; glad the indexed search goes back to 2016!
So the E Line is being totally rebuilt on Huntington/South Huntington Ave.
Upgrade report: https://www.mbta.com/projects/green-line-track-and-intersection-upgrades-2021
The tracks are being rebuilt in place although there have been proposals to run the tracks along the curb as shown below:
I know there are many actual and perceived issues with the concept but other cities seem to have been successful with the design and when I saw what they did on Brighton Avenue, where they took the entire right lane for buses, I wonder if it actually could work on Huntington Ave. If you are going to make such drastic changes on Brighton Avenue for buses, then you can probably justify similar changes on Huntington Avenue for LRVs and buses. The ADA requirements alone are probably enough to hang your hat on.
