sean99090900
- Jan 18, 2024
The smaller above-ground stops on the C branch now have real-time arrival signs
It's sooo nice. I moved back to the Boston area three years ago, and this week is the first time the red line has been running kind of how I remember back in the day.Post red line shutdown, looks like the line is largely free of slow zones with exception of the braintree branch, which continues to be a disaster. The looming September shutdown should do wonders for service frequency. By October 1st the line should be largely back to pre-pandemic travel times end-to-end.
If I had to guess, it might involve the switch at Kendall that they've been using for shutdowns, since trains often terminate at the station.Is there some way to figure out what the deal is with the last couple of slow zones in Cambridge? Those sections have been closed a few times this year, and I figure they've replaced just about everything at this point. What might be the cause of the last couple of slow zones?
According to TransitMatters' Data Dashboard:
Yesterday, there were 23 minutes, 41 seconds of slow zones on the Red Line. This was the lowest amount of slow zone time since June 2:
On the weekend of June 1-2, Shuttle Buses replaced service between Alewife and Harvard for track work. The last time there was full service with fewer slow zone time on the Red Line than yesterday was Memorial Day, May 27:
Memorial Day is obviously a Federal Holiday. The last workday there was fewer slow zone time on the Red Line than yesterday was February 3, 2023, weeks before The Great Slowdown of 2023:
More findings to come in a follow-up message.
We are a bit like NYC in that democracy has decayed pretty heavily. The reasons we got Eng are basically whoever had Healey's ear at the time. So we need to do elite persuasion, so that's 1) the mysterious "advocates" that have an elevated voice for what agencies listen to 2) the politician friends of the governor/transportation secretary (eg. that whole story about how one guy convinced Tibbits-Nutt to get rid of the layover at West Station)At this point, there’s likely a general consensus among transit-followers that Phillip Eng has dramatically improved the MBTA’s transparency, planning, maintenance, and management practices. There is a stark difference between the Poftak administration and the Eng administration and its honestly shocking how much of a difference competent management makes.
So, I pose the question: what can we collectively do to ensure that the next GM of the MBTA is of the Eng mold and not the Poftak mold?
I can honestly say that if the T continues moving in this direction, the Greater Boston area becomes a much more attractive place for residents, visitors, and businesses. It’s clear to me that having a competent GM of the MBTA is one of the most crucial roles for this region, yet it is not an elected position and the governor has typically not even stated who they are going to appoint prior to being elected. So, what can we do as Massachusetts residents, collectively?
PS: Eng for President.
Ranked Choice voting is a pretty big oneAre there paths forward that include systemic change so that we move away from Gangs of New York style “democracy?”
Was there any lessons learned from the failure to pass it, and is there any time limits to trying to get it on the ballot again? It really does seem like the best way to go, although can be incredibly complex to explain. Best I can think of was an NPR piece from Ireland explaining how it worked in their local elections.I agree. I volunteered heavily for that effort in 2020 before COVID shut things down.
Given that failed, I’ll ask my question again: what can we collectively do to ensure that the next GM of the MBTA is of the Eng mold and not the Poftak mold?
If the sub-answer is “implement Ranked Choice Voting,” then the real question is “what can we collectively do to implement ranked choice voting?”
Alternatively, are we doomed to sit here discussing things that should be while watching them slip away with the next administration?
Which makes sense - even after the physical plant is fixed, I'm sure they've got to go back through and update signals, ATO commands, etc. It's also probably better to have the operators acclimate to 40mph first if they've gotten used to running at 10/25 before asking them to do 50.The MBTA posted a video to their YouTube channel yesterday describing the goals of the September Braintree Branch shutdown and in it Phil Eng states directly that at the end of it the Red Line will be restored to full 40mph operation, and a few months following the completion of work speeds will be raised to 50mph on the Braintree Branch.
Red Line: Shuttle buses are currently replacing service between Braintree and JFK/UMass due to a derailed maintenance vehicle at Wollaston.
Over by 6:30 a.m.x.com
x.com
