WestMedford
- Nov 9, 2021
The Logan connection has functionally been implemented on the Rockburyport Line with SL3 service between Chelsea station and Airport Station.Take it up with Ed Markey. He secured the $4M federal grant to study this yet again...and yet again come to the same conclusion that all previous studies have. Namely:
- It doesn't work for Purple-Blue transfers unless you do a weather-protected APM between the CR platforms and the Blue Line headhouse, because people won't use it as a Logan connector when the luggage hardship is that pronounced over the walking distance. Done cheaper it's utterly negligible transfer numbers.
Whichever path a commuter takes it’s still a two-transfer ride (and Chelsea arguably better because you don’t have the long walk/APM Wonderland to Wonderland).
a. Chelsea CR Station <-> Airport BL Station <-> Logan
or
b. Wonderland “CR” Station walk to Wonderland BL Station <-> Airport BL Station <-> Logan
No need for more study unless you’re a pandering politician.
