I'm a bit annoyed that the downtown segment of the GL doesn't show the C/D/E between Gov't Center and North Station.Seen at Ruggles
View attachment 12029View attachment 12028
E branch to Tufts and D branch to Union Square.
The number of trains forced to cut out and loop early because of blown schedules makes that somewhat less than a moneyback guarantee.I'm a bit annoyed that the downtown segment of the GL doesn't show the C/D/E between Gov't Center and North Station.
I think they did it already on this map, but didn't they use the name Amory Street, not St Paul? Did they change it again, or did they mess up the map?Nice find.
I wonder if consolidating the BU stops will allow them to make the B line shorter. I hate how it looks so much longer than the D
Now you mention it yeah they made a weird decision to remove the two stops on the B line but didn't rename Amory or mark them as accessible. I guess its a halfway through construction snapshot (that we will likely see at Ruggles for the next 40 years if the other maps at Ruggles are any indication)I think they did it already on this map, but didn't they use the name Amory Street, not St Paul? Did they change it again, or did they mess up the map?
With the D branch now going past N Station I wouldn't be too surprised if the C branch is cut back to Govt Center which is what this map shows. So B to Park, C to Govt Center, D to Union Sq, and E to Medford/Tufts.I'm a bit annoyed that the downtown segment of the GL doesn't show the C/D/E between Gov't Center and North Station.
Unlikely. Cleveland Circle would have to crank up the number of Reservoir equipment swaps interacting with traffic in the square if loss of North Station Yard left them unable to subsist most of the time on middle-of-street turnbacks on the Cleveland Circle tail tracks.With the D branch now going past N Station I wouldn't be too surprised if the C branch is cut back to Govt Center which is what this map shows. So B to Park, C to Govt Center, D to Union Sq, and E to Medford/Tufts.
Wishful thinking at best since the B needs the Park crossover to *reliably* return to GC (i.e. without having to be aborted early @ Park every nth trip like the bad old days of the last time it called on GC). And that project won't be bid out before GLX opens.
No hallucinate. That was the service plan all along until now.I could have sworn that D was going to go to Tufts, and E to Union. Was I hallucinating?
Youre right, thats disappointing. I hate how geographically inaccurate that side of the map is.I think they did it already on this map, but didn't they use the name Amory Street, not St Paul? Did they change it again, or did they mess up the map?
The version numbers are sequential from when they started doing new-style rapid transit spider maps around '02-03 (whichever the first iteration showing the Silver Line was).Youre right, thats disappointing. I hate how geographically inaccurate that side of the map is.
I also just noticed it says December 2020 v.35
I like that they added the date. The "version" number seems unnecessary.
But that just adds confusion as to why theyre showing future service on a 2020 map? Unless this was printed in 2007.
Those extra 20something CAF type 9s aren't going to provide enough peak hour support that there won't be some wonky B to Government Center except sometimes Park? Or even better having the C turn at Government Center just a few minutes before a couple of late Northside commuter rail trains disgorge passengers into the Green and Orange line superstation?Unlikely. Cleveland Circle would have to crank up the number of Reservoir equipment swaps interacting with traffic in the square if loss of North Station Yard left them unable to subsist most of the time on middle-of-street turnbacks on the Cleveland Circle tail tracks.
Improving B schedule reliability enough to bring it back to GC Loop on permanent basis is the better outcome, and the one GLT direct-targets with stuff like the inbound Park crossover and surface signal priority.
The downtown turnbacks have often changed throughout history, which was the original rationale for not putting them on spider maps with a shelf life of multiple decades. It's pretty unlikely as it is that the full thrust of not-yet-finalized GLT improvements is going to leave all of the turnbacks (not to mention other stop consolidations) completely and utterly unchanged such that we won't have map versioning issues galore to stamp out in the wild. D to Union is already a last-minute change from the GLX ops plan of only a year ago which had it going Medford instead.
I much preferred the way the Green Line branches were represented in the early 2010s maps.I wonder if consolidating the BU stops will allow them to make the B line shorter. I hate how it looks so much longer than the D
The map already has the consolidated stops on it, though it mislabels Amory St. as St. Paul, which means that this design predates the final decision on station names.Nice find.
As far as I can tell, this is the first indicator of a change.Have they officially announced the routings, or is it still need-to-know (modulo the random map update)?
It'll be easy to update station names and accessibility designations with stickers, but would be much harder to change the number of stops along a line with stickers. So they probably set up the future "structure" of the B on this map, then they'll update with final name stickers once the stop consolidation is complete.Now you mention it yeah they made a weird decision to remove the two stops on the B line but didn't rename Amory or mark them as accessible. I guess its a halfway through construction snapshot (that we will likely see at Ruggles for the next 40 years if the other maps at Ruggles are any indication)
I don't see why the GLX termini need set line pairings at all. Why not designate Medford/Tufts as "1" and Union as "2" (and N Station as "3" and Gov Center as "4") and then allow variable alpha-numeric pairings across the Green Line in order to maximize operational efficiency?As far as I can tell, this is the first indicator of a change.
Line pairings haven't been much of a topic at public meetings, however, so this would've been easy to escape notice.
Going from 4 regular service patterns (in addition to the rando exceptions and peak-hour short-turns) to up to 16 regular service patterns doesn't seem to be particularly intuitive for new or infrequent users.I don't see why the GLX termini need set line pairings at all. Why not designate Medford/Tufts as "1" and Union as "2" (and N Station as "3" and Gov Center as "4") and then allow variable alpha-numeric pairings across the Green Line in order to maximize operational efficiency?
Really, you don't need branches at all. The trains have the destination sign on them. Just use that - who cares about what letter is on it?Going from 4 regular service patterns (in addition to the rando exceptions and peak-hour short-turns) to up to 16 regular service patterns doesn't seem to be particularly intuitive for new or infrequent users.
B1 B2 B3 B4
C1 C2 C3 C4
D1 D2 D3 D4
E1 E2 E3 E4
Also, woe be the service planner, operations manager, and operators/motorpersons that have to create/manage/get some likely wildly-interlined schedules.
