HelloBostonHi
- Apr 17, 2018
What part of the critical path do you see that impacting?I’m setting the over/under at a three month delay for the Medford Branch opening due to the asbestos remediation near the High School. Does anyone want to take the under?
Glad they're getting a head start on the rusting, wouldn't want it looking too clean when it opens
What is the net opening date before your delay and after?I’m setting the over/under at a three month delay for the Medford Branch opening due to the asbestos remediation near the High School. Does anyone want to take the under?
May 2022 to NET August 2022.What is the net opening date before your delay and after?
It's been discussed on here before but I think the primary reason is reducing the number of people who need to change trains, D&E have the most OD pairs with riders on the extension.Does anyone have any insight as to why the E branch was chosen to run on this extension at all? I recall the reasoning for D to Union and E to Medford being that E was shorter. With the E branch running in mixed traffic on the other end of its line, it seems like the Medford branch will be plagued by bunching, delays, etc. I assume B or C with full signal priority would be more reliable.
It seems like billions invested in fully grade separated transit and 60 mph tracks on one end of the line are a bit wasted when the other end is 5mph in mixed traffic.
Here's the official reason:Does anyone have any insight as to why the E branch was chosen to run on this extension at all? I recall the reasoning for D to Union and E to Medford being that E was shorter. With the E branch running in mixed traffic on the other end of its line, it seems like the Medford branch will be plagued by bunching, delays, etc. I assume B or C with full signal priority would be more reliable.
The specific branch assignments are a reversal from earlier plans, which called for extending the D branch to Medford and the E branch to Union Square. Asked about the switch, Pesaturo said Friday that the D branch — which is by far the longest arm of the four Green Line branches — was assigned to the shorter extension to Union Square to make it a more reasonable length for trains.
“A shorter trip than the D branch, E branch trains have been assigned to the longer leg of the extension (Medford),” Pesaturo said in an email.
Pesaturo noted that those two branches serve the Longwood Medical Area, and this will minimizing transfers for riders who take the commuter rail to North Station, as well as the Green Line Extension.
Also purely speculation but I think having the E run to a terminus could help it's headway management compared to turning at govt center. The lines that turn at government center have to start their outbound trips pretty much immediately, so any uneven headways are compounded. Running to the terminus allows them more ability to space the trains as they send them out.
The E branch is eternally bunched.My understanding:
B and C were the most bunching prone and are already fairly long operator shifts
The D and the E were more likely to be unbunched.
I think it’s pretty much as simple as: the D and E serve Longwood, the B and C don’t.It's been discussed on here before but I think the primary reason is reducing the number of people who need to change trains, D&E have the most OD pairs with riders on the extension.
What could / is the T doing to reduce this bunching? Transit signal priority seems like an obvious one, but this article mentions software that was piloted on the D branch in 2017 to reduce bunching: https://commonwealthmagazine.org/transportation/t-trying-to-speed-up-green-line-trains/The E branch is eternally bunched.
D branch is moderately better
But neither are anything close to consistent compared to the Blue Line
So what letter will the new GLX line be given to the very end of it? I'm thinking maybe F. All the letters before that are already taken.![]()
