Missing the forest for the trees here. If GLX is falling apart because of substandard materials, that's not good.
Says the person who injected the xenophobic aspect into the conversation. Grow up.
I believe they now have an in-house sensor rig they can swap to any trolley in the revenue fleet to do the geometry testing, and don't have to stock or lease any specialized work equipment. It's just a bunch of laser guides...nothing all that bulky. The old Boeing geo work car wasn't exactly a hyper-custom beast...it just had a permanent rather than portable sensor rig so they didn't have to vulture revenue cars for the inspection shift. The 3 HRT lines have long used portable sensor rigs in lieu of any specialty geo cars. Commuter Rail's rented Amtrak Corridor Clipper geo car is likewise a pretty basic setup; the NEC-member states' CR agencies simply coordinate their inspection schedules so it's in constant rotation around the country rather than each agency bothering to outfit one of their own coaches with sensors.Err so the GL track geometry LRV and 2 more LRV based work trains were non operational and scrapped without direct replacement in 2020. https://www.universalhub.com/2020/imagine-getting-these-trains-under-christmas-tree
I'm not actually sure what the MBTA has been using since for its geometry testing, but probably a hi-rail of some sort or contractor equipment?
Source rail is all pretty generic and bulk-supplied. The only differences is that RR rail comes in 1/4 mile ribbons to be welded together, while rapid transit rail comes in 800 ft. (or .15 mile) ribbons to be welded together...the shorter lengths so that the rail drop can navigate tighter rapid transit turning radii. Commuter rail generally uses 136 lb./yd. weight rail (sometimes as low as 100 lb./yd. on turnouts, but the T sticks with the 136 lb. mainline & freight 'superset' weight for bulk ordering purposes). Rapid transit standardizes on 100 lb. rail pretty much everywhere worldwide. Bulk rail usually ships at a RR wheel profile (because that's the majority of worldwide volume for rail, and thus fetches the best bulk rate), and for rapid transit installs they simply run a rail grinder over it to change the profile to rapid transit wheels. That ends up easier than buying specialty-ground bulk rail, so most rapid transit systems apply the re-grinding post-install. The specialized Loram rail grinders were very busy on the GLX corridor in 2021 and early-'22 working over the track before the first test trains went on the corridor.That’s a good point that opens up a whole bunch of new questions; although l wonder if the wheel profile between the modes could be a partial factor? Although my recollection is that the LRV profile was more forgiving than mainline.
I mentioned the wheel profile in the sense of tolerance to gauge deviations. Per the headline of most recent Globe article on this:As mentioned, the geometric defect detected was that the tracks were spaced too closely together, which is an alignment problem not a wheel profile (or wheel profile wear) problem. It's not clear what's causing that, but you can rule out a problem with the profile/rail grinding.
Right. I said this in the other thread but the T owes the public an explanation of the risk management and tradeoffs with slow zones in general here.I mentioned the wheel profile in the sense of tolerance to gauge deviations. Per the headline of most recent Globe article on this:
“Green Line extension track, which T says ‘has always been narrow’”
AKA the gauge has been ‘too narrow’ for a year with 0 issues running at line speed. So either for the past 12 months every green line train had a significant risk of flying off the rails and the T put riders at an unacceptable risk of being in a derailment, or the 3 MPH slow zones are overcautious overkill. Take your pick which is worse.
This is what I don't get. . .Right. I said this in the other thread but the T owes the public an explanation of the risk management and tradeoffs with slow zones in general here.
If the trains have been running for months on defective track at higher speeds, in some cases significantly higher, what risk of derailment were they running? If that was very low, why slow them down so much and so widely? The answer may be "because we don't have any idea what we're really doing with regard to track maintenance" but if so then why would anyone trust them to fix it or even run any trains at all?
If the answer is "because we decided six months ago we don't want to risk even a .0001% chance of a derailment" that seems like a bad way to run a mass transit system honestly, and I would argue that the long term harm to ridership to say nothing of the short term pain for riders make that a bad choice. Especially when there have been numerous safety incidents recently that have nothing to do with the track and prompted few similarly dramatic changes.
If the risk of derailment is relatively high, but the defect can only be detected with the geometry train, why do they only run the geometry train infrequently?
If we ran a geometry train on BART or Baltimore light rail or whatever, would we find similar defects? If so, do they have a less strict standard for slow zones? Why? If not, and the MBTA is singularly bad at this, why aren't we firing everyone and hiring whoever can fix rail as soon as possible? There's just no good logic here.
Also, his rush to get the new Red & Orange Line trains in. So much of a rush it was, that proper inspections of the new cars weren't done right & properly. Things kept going wrong with them & they were seemingly being yanked out of service for every little thing!Tin foil thought: This is yet more fallout from Baker’s rush to get the GLX grand openings done during his term.
MBTA general manager Phillip Eng said he’s focusing on fixing the problems on the Green Line extension that are forcing trains to travel at just three miles per hour along the transit agency’s newest piece of subway.
“I ride that Green Line extension every day, as well. I talk to the riders. I fully understand their frustration,” Eng said at a MBTA board of directors meeting Thursday. “These types of occurrences are unacceptable, and that’s why we’re working very hard in terms of capital delivery and working through these issues earlier. What we are doing now though is we are going to make sure we address those recent speed restrictions promptly, timely and focus on safety.”
The Green Line extension branches to Union Square and Medford/Tufts, which opened in March 2022 and last December, respectively, are in such bad condition that the agency is now forcing trains to travel at a walking pace over sections that add up to more than one mile long, making rides unbearably slow less than a year after the full project opened.
The MBTA has said the rails are now too close together in many areas, making full speed train travel too dangerous. The T said the Green Line extension tracks were built “narrow,” but have narrowed further to an unsafe degree since the project opened last year.
The agency has not explained why the project was built with narrow tracks or why such serious problems are happening so soon after it opened, or who is responsible.
No chance that it's anything tie-related. Concrete is superduper rigid from the factory, and wood...while more flexible...doesn't move enough to cause alignment issues until the ties are at end-of-life (which GLX's obviously aren't).Is there a chance the concrete ties were laid "green" / not fully cured and shrank a bit? What's the tolerance on the distance between rails??
