BostonUrbEx
- Mar 13, 2010
I'm cautious about going under... I think vertical clearances should be maximized, potentially for autoracks, plus electrification.
F-line has said he thinks there is enough running room to bury it (as Fitchburg @ Waverly). Under or over, you are right that it should be addressed in GLX Phase 5 (GLX@MVP)
Moving the West Medford CR station to the south side of 60 and providing a pedestrian connection to the Mystic Valley Parkway GL station makes a ton of sense. I've always thought the lack of a CR connection was one of the biggest missed opportunities of the GLX, and that station is in dire need of an upgrade.
There's actually a lot of bus upside out here, with the routes ripe for a reconfiguration after GLX gets going. The 94 and 80 hit Davis @ Red, College Ave. @ GLX, 16 @ GLX, and West Med @ CR (the 80 turning out a block away). That kind of transfer chaining is going to see increased, not decreased ridership under GLX. Check the travel times on some of those routes...it's FAST around the transfer chain. The only thing lacking are the frequencies making the speed attractive. With the extra demand GLX pushes out there I can definitely see the need for some consolidation/reshaping of the diverging routes and more frequencies on the lateral trunk connecting the transfers.
So that's another thing to have to consider: the Yellow Line doesn't get replaced, its demand profile just gets thrown in a blender and what emerges ends up supcharged from today...but not necessarily on the same patterns because of the way that chain of nearby transfers changes the game.
Rendering of the new green line cars being bought for this project
http://www.caf.es/en/productos-servicios/proyectos/proyecto-detalle.php?p=271
http://www.universalhub.com/2015/imagine-green-line-branch-along-mem-drive
That is still the early rendering they put out when the contract was first awarded last year, not the final design. The cars will have front doors (the other image if you go to the CAF web site gives the false impression the cars have only two doors). The coupler type will also be compatible with those on the Type 7s and Type 8s (for towing/pushing, the cars won't run in regular trains with the older equipment).
Isn't the front door in that rendering just on the other side? Current GL trains only have front doors on the right side.
Your link didn't work for me, but Gilbane New England has a photo of their viaduct footings (I assume this is to carry GLX through the junction @ the future yards beyond Lechmere but before Union Sq and Brickbottom
Bump.
So the draft FY 2016 MassDOT and MBTA CIPs have been released. I've had a little bit of fun comparing to the latest 2014-2018 MassDOT and 2015-2019 MBTA CIP, there's a lot to say, but no one thread that's entirely appropriate. As FY 2016 concerns GLX however, the 2015 programmed funds for the Medford extension have been wiped clean from both the MassDOT and MBTA 2016 capital budgets. Obviously without the full 2017-2022 CIP it's impossible to say if/when it's going to happen, but a new line item has been added the GLX in the form of mitigation (i.e. expanded bus service along the corridor, purchase of addition RIDE vans). The State's and the MBTA's FY16 funding shed about $200mil (as far as I can tell - with the State projecting 151mil + 100mil of Federal/non-State funds compared to 428mil projected for 2016 in both the 2014 and 2015 CIPs, I would doubt it's insidious - if work is delayed then capital outlay is too). There's more to uncover - the roughly 300mil divergence from the current draft and the projected spends of the old CIPs is mostly down to the axing of any serious DMU implementation, and tapering down SSX funds and SCR funds for the time being.
Bump.
Without taking the time to read it, it's also possible that since Federal reimbursement is locked in for GLX, the State funding has been wiped from the CIP. In any case, this is under construction and fully funded to College Ave, so I wouldn't draw any (as you say) insidious conclusions.
