Ron Newman
- May 30, 2006
I love ivy-covered walls, but ivy can actually damage them if it isn't kept under careful control.
Most of the damage actually occurs when the ivy is removed; that's when you can expect some mortar to come out of the joints. When they did that at Harvard and Yale, they repointed the mortar joints --something that's often done anyway every sixty years or so.Ron Newman said:I love ivy-covered walls, but ivy can actually damage them if it isn't kept under careful control.
Well, I did your assignment, statler, but it didn't have much effect. "Understanding" doesn't do the trick.statler said:Rather than whine about how the mouth-breathers don't "get it", why don't you explain exactly what makes this this building so great? Do it in a way that even the knuckle-draggers can understand. Educate more, bitch less. If Einstein can turn a byzantine mathematical formula in a pop cultural icon, surely this can't be so difficult.
I'm really trying to like this building. You've already convinced me it should be saved, but nobody has done a good job of explaining why.
ablarc said:Well, I did your assignment, statler, but it didn't have much effect. "Understanding" doesn't do the trick.
Certainly, but perhaps not exactly the way you have in mind. To an astonishing extent, this building HAS NO FACADE; inside and out are the same:IMAngry said:Is it possible to save the facade, but renovate inside?
That building has a facade and an interior. The former was kept, the latter discarded.I'm thinking the typical renovation such as the Hearst Tower, in NYC.
Sounds like they need to install some lights and some signs.The existing structure is terrible, inside. It is terrible. You can't get anywhere, and it's the darkest building. No matter what floor you're on, you feel like you're in the basement.
That could make it a neat Turkish bazaar.Yes, so it fulfills its purpose if it is supposed to illustrate the byzantine labyrinth workings of municipal government.
A really good idea.Architects love the building? Great, send in the BAC, and let them rent out all the extra space.
well, i think because of its height, it will always be just "nice", but if it were up in the 800-900+ range, it would be a more well known building. It did actually win second place in that emporis thing if i recall correctly.
am I the only person who thinks 111 huntington is one of the prettiest modern glass towers in the world?
"prettiest modern glass towers in the world"
