That works when you have a grid.The left turns are definitely concerning.
In Latin America, the land of the center running bus lanes, they simply dont allow it. Want to turn left? Then you turn right and then right and then right again.
For the new QA bus garage in design... Does anyone know if the T expects to repurpose the existing Lowe's building, or tear it down and rebuild? Being quite new post and beam construction, it's presumably not that hard to add multiple additional roll up drive in doors to the envelope, and use as is. It'll probably compromise efficency, but it's likely faster and a decent layout could help. Not knowing ifs its prestress preform walls or masonry, I would only expect the floors to be an issue; warehouses are usually built to a floor loading between 6-12 kN/m², but I don't know where a Lowe's would be in that universe, or what a bus garage would need to be at. It's also probably not big enough for expansion, though it is massively bigger than the existing Quincy garage.
Also, did the T acquire the whole site? looking at the Quincy GIS, that is one irregular lot, with a healthy chunk of wetlands, and what looks suspiciously like a former RoW for Penn St. Obviously, the neighborhood access to QA from the NW is still probably going to be the bugbear in public meeting.
In Boston, if you turn right, then right, then right, you end up in Cambridge (or New Hampshire).
Doesn't seem like too big of a deal to me? Route a boardwalk along the edge of the site/through the wetland area from the town parklet thing on Columbia St over to near the Deco building. Could probably make it look nice and like a modest expansion of their little park.
If people want more access, fixing up the sidewalk and moving the lightposts along the Burgin Pkwy and building an access along the northern edge of the site from Penn St doesn't seem like a big deal either. I suppose walking along a highway isn't some wonderful experience, but neither is walking through a strip mall parking lot.
That's probably true, but it's the constant theme running through any news coverage of this proposed garage. I think for neighbors a pleasant maintained retail parking lot sounds like a better proposition than trusting the T and walking by a industrial site.
As is turns out, the seaport happens to have a pretty decent grid. It's not Southie, but it's certainly not the north end.
I get that my lack of sympathy wouldn't win any points with Quincy-ites, but if you live in that neighborhood and have a problem with industrial operations, I don't understand what planet you were on when you moved in there to begin with.
There's auto body/car repair shops all over the neighborhood, various building/contractor supply firms, the gravestone maker, and a sea of truck and equipment storage for various firms (including a garbage truck firm - I'm sure they smell nice in summer) in the surrounding area. Not exactly some sort of quiet, idyllic backwater.
That said, this is possibly crazy pitch territory, but is there any reason that the T shouldn't persue a land swap with the Home Depot once it acquires the site? I know the T seems to have already committed to the Lowe's but 15% design is a fairly low bar, and feels like the T can justify purchasing the site, say it's tried, and here's a better option. It's basically identical use for the Lowe's site, which is actually slightly bigger, with a bigger newer building, with much better visibility for retail, about the same parking. A Lowe's and a HD can't be that different really. The current HD site is actually zoned Industrial, owned by HD corporate, so no leasehold issues, and while ~2 acres smaller, has much less wetlands. It's also tucked into a nearly invisible gap between Burgin, the station garage ramps and the tracks. No abutters at all, no ped access considerations, but it has what looks uncommonly like an Old Colony spur. It can't hurt the T to have a healthy chunk of land right next to it's rail RoW.
There is movement on the South Station to Black Falcon section which I believe has already been discussed on here a few posts back: https://www.boston.gov/departments/transportation/summer-street-multimodal-corridor-improvementsHas anything progressed on this awesome project? (Article and map from December 2019)
Boston Officials Pitch New Bus-Priority Corridor Between North Station and Seaport![]()
The proposed “Center City Link” bus route would build a corridor of bus-priority infrastructure to link North Station, South Station, and the Seaport District.mass.streetsblog.org
The proposed "Center City Link" bus route would build a corridor of bus-priority infrastructure to link North Station, South Station, and the Seaport District.
I know its just a rendering, but that could sure use some greenery... even planters could make it not seem so desolate
