TheRatmeister
- Sep 23, 2023
As of the most recent schedule, yes, that is where the short-turns terminate.Did they change the terminus on the Fitchburg Line to Littleton/495 instead of S Acton?
I'm pretty sure the short turns being extended to Littleton dates to just about when the new station opened as part of a double tracking initiative, so 2013/2014 ish.As of the most recent schedule, yes, that is where the short-turns terminate.
Yeah I continue to love this map. Great stuff.I've taken the occasion of Lynn/Ashland reopening to update my improved CR map to fix a few mistakes and things I didn't like. Hope some people find it useful
Maybe it's just because I'm used to it, but the 2nd one just looks... off. It's also not how the regular Rapid Transit Map does things, and I am trying to match the "official" style the best I can. Who knows, I might play around with it whenever I update the map next, probably for the spring schedule whenever that comes out.Yeah I continue to love this map. Great stuff.
One small stylistic note -- when either the line or the label is diagonal, I think alignment is better done perpendicularly to the line, aligned with the corner of the label. You've aligned it horizontally, which does make sense, but I think creates a slightly more-than-ideal distance/whitespace between the label and the stop.
So, before and after:
Dotted line shows the horizontal alignment that I think you were going for, short solid line suggests the alignment approach I'm trying to describe. (The Norwood stops have also been adjusted, without the alignment guides, so you can see a more natural version.)
Again, this is just my stylistic preference, so totally up to you.
Yeah, I dislike it on the official map tooMaybe it's just because I'm used to it, but the 2nd one just looks... off. It's also not how the regular Rapid Transit Map does things, and I am trying to match the "official" style the best I can. Who knows, I might play around with it whenever I update the map next, probably for the spring schedule whenever that comes out.
Oh the inconsistency on the official maps drives me bananas. Angles that look like they're 45 degrees are sometimes 44.9999 degrees or something stupid (RL south of N. Quincy is an example), and lines will just arbitrarily change width sometimes, not to mention basically every line being a different width. For both of my mapping projects (CR but accurate and fantasy rapid transit) I've avoided doing a full ground-up reconstruction so far, but I'll probably need to bite the bullet at some point.Yeah, I dislike it on the official map too
Like. It's not even aligned with the center of the stop circle (which, to your credit, your map does nicely align):
The centerline of "Mission Park" actually misses the top of the circle entirely (though I think this is not consistent with all stops).
And to my eye, the alignment is confusing because it also looks somewhat vertically aligned.
I mean, heck, the horizontal line from the center of the stop circle barely intersects the label:
(This is one reason why I tried to avoid diagonal lines as much as possible -- and non-horizontal labels altogether -- on my maps.)
There are five stops at Forest Hills in each direction, but they are definitely limited to main direction commuters. That's the kind of thing I think most people miss, if their thinking is aligned with a particular pattern. Great observation, and I think you are right, that it would get more ridership with additional Forest Hills stops, spread more evenly throughout the day.Was thinking about this today as a reverse commuter on the Franklin Line and the transit frequencies seem to be a primary driving force behind reserve commute ridership. Before the return of Foxboro service the Franklin Line was pretty bare every morning and evening but since its return and introduction of 30min headways to Norwood there's been double the passengers outbound each morning. There's also the fact that the 34E basically parallels the line to Walpole and every day the bus is full beyond Dedham during peak. If the Franklin Line stopped at Forest Hills for a few trips it'd probably get even more reverse commuters.
The two most significant cities in New England should have much more frequent bidirectional rail service if the T wants to attract more riders and state governments want to stimulate economic growth in their capitols.
Oh yeah, if you like that stuff, you'll love this.Oh the inconsistency on the official maps drives me bananas. Angles that look like they're 45 degrees are sometimes 44.9999 degrees or something stupid (RL south of N. Quincy is an example), and lines will just arbitrarily change width sometimes, not to mention basically every line being a different width. For both of my mapping projects (CR but accurate and fantasy rapid transit) I've avoided doing a full ground-up reconstruction so far, but I'll probably need to bite the bullet at some point.
Presumably it’s practically a deadhead run where they are just trying to get the set back to a yard for the night. There are/have been other such moves included on the schedule, but it’s not always consistent. I wonder if conductors get paid differently depending on whether they are running a revenue vs non-rev trainwhere the last inbound Foxboro train now runs express for... some reason.
“Lynn Interim,” I love it. Imagine if that were printed on the actual signs at the station.
And also, the alternative was just putting "Lynn" but then needing to put an explanation somewhere that it's not that Lynn station, it's a different one.That's actually what the MBTA website calls it: https://www.mbta.com/stops/place-ER-0117
And here's the SCR+Summer Ferries version:
To both of these, I'm still just like, "Why?" I guess it's sorta an interesting philosophical question, but seems like a distinction without a practical difference?And also, the alternative was just putting "Lynn" but then needing to put an explanation somewhere that it's not that Lynn station, it's a different one.
Went down to Pawtucket the other day (Saturday) and the return trip further cemented my belief that the Providence Line needs more service. I was on train 1806 the 11:50am out of Providence. While waiting at Pawtucket/Central Falls the platform looked like a typical weekday rush-hour load of 30+ people which led me to think this was going to be a busy weekend train. I was unprepared for the entire train to be 70% full upon arrival in Pawtucket, the second stop on the line. A 6-car train of entirely bi-level cars with all open except the Cab Car and there were slim pickings for seating. It also wasn't like single riders were taking up the 3 seat benches making them "full" but people doubling up. There was also a scramble to figure out where to put all the baby strollers and bikes but that's a whole issue on its own. All remaining stops had about the same traffic as Pawtucket but with some passengers alighting at each one to free up room. That on its own showed the demand to take the train to Providence instead of Boston and surprisingly the train was less full upon leaving 128 than it was leaving Pawtucket.The two most significant cities in New England should have much more frequent bidirectional rail service if the T wants to attract more riders and state governments want to stimulate economic growth in their capitols.
Hence full electrification and EMUs.If you want higher frequencies you need faster acceleration and higher top speed for commuter equipment. And greater capacity with more sidings. It's tough keeping a diesel train, making frequent stops, ahead of an electrified Amtrak train making limited stops, moving at much higher speeds.
@Teban54 and I should take a look at the weekend ridership, because yeah, this sounds intriguing. I know they've been advertising the weekend pass pretty heavily over the past couple of years, so maybe that's starting to pay off?Went down to Pawtucket the other day (Saturday) and the return trip further cemented my belief that the Providence Line needs more service. I was on train 1806 the 11:50am out of Providence. While waiting at Pawtucket/Central Falls the platform looked like a typical weekday rush-hour load of 30+ people which led me to think this was going to be a busy weekend train. I was unprepared for the entire train to be 70% full upon arrival in Pawtucket, the second stop on the line. A 6-car train of entirely bi-level cars with all open except the Cab Car and there were slim pickings for seating. It also wasn't like single riders were taking up the 3 seat benches making them "full" but people doubling up. There was also a scramble to figure out where to put all the baby strollers and bikes but that's a whole issue on its own. All remaining stops had about the same traffic as Pawtucket but with some passengers alighting at each one to free up room. That on its own showed the demand to take the train to Providence instead of Boston and surprisingly the train was less full upon leaving 128 than it was leaving Pawtucket.
I would caution against overinterpreting the T's use of full bi-level trains.Granted this is a holiday weekend but close to this level of loading on midday weekend trains is typical of both the Providence and Worcester Lines and the T knows this because they run full bi-level trains with multiple conductors for these trips (and the typical loading is displayed on the online schedule). Surely the additional paying riders attracted by running hourly on these lines on weekends would reduce the additional costs of doing so to make it worthwhile.
This is a really interesting thought -- run faster and/or more frequent service to key stations (cities and park-n-rides) to attract leisure passengers on weekends. I think the conventional wisdom has always been that weekend demand is anemic and so you should just run the bare minimum anyway. But you're presenting an intriguing theory: latent demand might be higher but with a different profile and set of needs than weekday.Another idea would be higher-fare weekend express trains filled into schedule gaps. Running a few round trips that are either normal weekday fare or the $20 event fare but make very limited stops could add more flexibility to people taking the train to one of these cities and make a very attractive alternative offer to driving. For the Worcester Line this could be BOS-Framingham-WOR with possibly Southborough for the I-90/495 park n ride and for the Providence Line BOS-128-Mansfield(?)-Pawtucket-PVD. Doing four round trips, 1 mid-morning, 1 midday, 1 afternoon, and 1 evening could cover all the common weekend travel times with an express option. A summer pilot with 4-car trains could be a good start to determine how attractive this is to the public.
I addressed this in this post a few weeks ago. So long as so many of the MA intermediate stops rank in the Top 10-25 of boardings on the entire Purple Line system, the state is going to have very low motivation for running any RI-centric express flavors. It's flat-out passing up revenue into their coffers on a line that quite likely makes the agency money. It would require Rhode Island to up its subsidy generously to offset the in-MA revenue losses, but for all the RI State House's bellyaching about lack of express flavors in general that's something they thus far refuse to do. It takes two to tango. Massachusetts isn't incentivized on the revenue side, and Rhode Island isn't incentivized on the cost side.Another idea would be higher-fare weekend express trains filled into schedule gaps. Running a few round trips that are either normal weekday fare or the $20 event fare but make very limited stops could add more flexibility to people taking the train to one of these cities and make a very attractive alternative offer to driving. For the Worcester Line this could be BOS-Framingham-WOR with possibly Southborough for the I-90/495 park n ride and for the Providence Line BOS-128-Mansfield(?)-Pawtucket-PVD. Doing four round trips, 1 mid-morning, 1 midday, 1 afternoon, and 1 evening could cover all the common weekend travel times with an express option. A summer pilot with 4-car trains could be a good start to determine how attractive this is to the public.
How's this?Nice map, though it should include the seasonal CapeFLYER service (perhaps as an arrow from just north of the planned Middleborough station).
