Where do I even begin with this insanity. . .
Moving the Orange Line tunnel down deeper seems like a good place to start - there's no surprises under the NEC and if you bury the Orange Line, quad-track to FH doesn't need to mean expanding the ROW. Hell, you could shrink the ROW at that point if you wanted and still have more capacity than the current 3+2 setup.
There is a big difference between the SW Corridor cut and digging
underneath the SW Corridor cut. The current cut was studied since the 1950's for I-95. But at no point did planners ever talk about taking any structures--highway or rail--subterranean there. That was not EIS'ed. You are now proposing a Big Dig here requiring a rip-up/rebuild of all the SW Corridor cut pilings and the air rights roof to support a lower-level tunnel for the OL. That is even MORE invasive and twice as expensive than the dismissed quad-track widening plan. By $B's in construction and a very very expensive EIS.
And there is a significant benefit to pushing the Orange Line deeper - one of the things the Big Dig fucked up is that the NS Link can't go through it or over it, it has to go around (which essentially means 'under' in this context.) Amtrak and Commuter Rail aren't capable of handling the kind of incline you get if the portals go where you're saying they're going - not now, probably not ever, and not even if you say 'well the entire tunnel is going to be incline!'
South Station-area building pilings and the transition zone into the main tunnel are the ruling grades on the N-S Link. It does not matter what you do with the portal tunnels...you have to get into that cleared-out space under I-93 on 1-2% maximum RR grades. That sets an absolute ceiling/floor on the level South Station Under has to sit at. And that ceiling/floor sets the left/right dimensions under the building pilings for the platforms. Then the minimum-dimension run-up space for the tunnel merge and crossovers sets the floor of the incline for the portal tunnels. Then there's a set space reserved to snake around the Pike/Ft. Point tunnel incline and start the curve onto the NEC. You're on a sharp curve at almost Albany St. before you can start the incline back to the surface.
What, I ask, does blowing up the OL tunnel and blowing up BBY to move the OL and blowing up part of the SW Corridor tunnel do to improve trip times through the Link when the grades are locked solid and unchangeable east of Albany St. The portal's at Washington because that's where 1% grade spits you back on the surface from whence it came. Lengthening that does absolutely bupkis with speeds because it's still restricted on the curve, just as tight on the merge/crossovers/station, and just as steep to North Station.
It does nothing. It is purely cosmetic. You are designing things that look nice on a 2D map but do nothing in the real world. And furthermore, you're confusing the object of your ire with this setup. Because relocating a fully-functioning Orange Line does nothing. If you want this perfect setup the only way to do it is re-Dig the Big Dig. Which is where it is because of its own unprecedented engineering challenges. We are LUCKY that they had the foresight to provision a Link. Extremely lucky.
But go ahead...propose blowing up the Big Dig as a serious solution. That's the only thing that's going to improve trip times. The rest is cartographic eye candy, no more.
We no longer have any actionable data. Our "actionable data" is now one decade and one boondoggle out of date.
Did the building pilings change under the SW Corridor in the last 10 years? No. That was an engineering feasibility study. Engineering does not change in 10 years. Engineering studies do not have an expiration date, and there is no engineering in this town that will ever again require pulling wholly new and untested methods out of the engineers' asses like the Big Dig did. Engineering studies routinely have a shelf life of 30 years or more. Re-studying doesn't turn up "Eureka!" revelations about feasibility by squinting harder and suddenly seeing a neat-and-tidy solution. The SW Corridor widening feasibility study concluded that any build would've been very messy, disruptive, slow, and expensive. Can't squint again and again at this expecting a different result...that's the dictionary definition of insanity.
So what I'm suggesting is, let's do this perfectly. We really do only have the one shot at this - whatever the North-South Link does not fix about the last mile jog in is never getting fixed.
Then tell me how this gets done perfectly without undoing and redoing the Big Dig, the SW Corridor, the Mass Pike, dozens of building foundations, dozens of road bridges, an entire subway line, etc. etc. And how that is different from 60's Urban Renewal planners' sense of aesthetic perfection? Does wiping the slate clean necessarily leave a net-positive behind? The pursuit of perfection has limits. Dig in if you will, but what you're pushing at is Urban Renewal redux disruption as a solution for some relatively minor transit flow corrections that Amtrak, the state, and the federal gov't in their wildest HSR dreams don't consider necessary.
So, yes, sorry, but I consider straightening for 200 in Delaware and this to be apples and oranges, and I'm going to keep pushing the boulder up the hill. To me, it's better it takes me the rest of my life (and I just turned 21 last Wednesday, I expect to see the 22nd century in my lifetime) to see another $25B tunnel that fixes (almost) everything than a $10B tunnel that doesn't fix much and has its own host of issues, transformative or otherwise.
You better hope to be living to Age 300 then, because the concept of value-for-money isn't going to change in this century.
Frankly, I think Fred Salvucci's foresight to push, push, push for for the Link provision we've got is the gift that will keep giving into the 22nd century. Without him, we have no physical path at all to do this. Do you really think this a bad thing?
