Portlander
- Apr 14, 2010
The circus is packing up and leaving town!
The thought occurs to me that, if it weren't divided between Gates 12 and 14, you could cut a hole in the side in the middle of it and park a food truck (with a scissor lift as needed) there to serve it! Although I'm sure in this city Mr. Tuna would immediately grab the license.That is one long passenger transit bridge!
Having been that guy, I'd still take the new arrangement with level deplaning and no wind or rain over the prior situation. Not to mention, that guy is going to be exiting on the other side of the terminal soon enough, and I don't believe that the number of people who choose "I'll wear shorts on the plane and change in the john at the terminal" is statistically significant.Without proper insulation, there is no realistic scenario for this entire length to offer comfortable temperatures. Whether it's January and February below zero, or July and August above 90 degrees, it's going to become a kind of mad dash to the plane or terminal. It's always less then, when cutting corners to save money. This should have been a terminal extension, though a narrow one. That guy arriving from Florida with flowered Bermuda shorts on is due for a big surprise.
Agreed. If you know that a metropolis is going to grow, naturally its transportation needs will follow. As I've said, a big garage could be built behind the Hilton Garden Inn for parking and rental cars. I don't think the neighboring dead people (in the cemetery) will mind. And the current parking lots for rental cars across from Embassy Suites could be removed and replaced with green space. Just find the money. Create another passenger tax (50 cents). You got my two quarters to not park outside in the winter.I really do believe it is short sighted not to go ahead with the parking garage expansion at this time however the NIMBY's knew what they were getting when they bought property next to an airport ...
Residents call for new board to oversee Portland Jetport
A neighborhood group wants to increase public input on projects and operations at Maine's largest airport.www.pressherald.com
