Transit Twitter has been lighting up about trackless trollies lately (since the Biden admin wants to promote battery powered buses). Are there any reasonable pitches to convert some bus lines to TT? Personally I don't see it happening, but I'm curious if there is a hint of possibility.
IF we did electrics right (which the T seems utterly against), the first BEB rollout would be in-wire charging TT's that could run for an extended range off-wire. As that gets around the issues of inadequate charging range for running average route lengths on the system, climate-related charging range issues with the NY/New England region in particular, and greater required spare ratios for charging downtime than the T currently has garage capacity for.
In that case, a short wire extension from North Cambridge carhouse to Alewife (via the proposed Alewife-to-Mass Ave. busways) could extend the 77A TT more usefully to Alewife under full wire (where there's a convenient 600V substation to loop the source back into), electrify the whole 77 with a power switch to/from battery at Alewife Brook Parkway, and allow for closure of North Cambridge garage (Watertown then becomes TT maint headquarters, with Alewife busway just getting a few idling bays). You would also be able to electrify the 75 by swallowing the 72 with power switch at Aberdeen Ave. You'd also be able to rather easily BEB the 74 from its Garden/Concord Ave. wire overlap, as that's probably adequate-enough wire charging time to feed Belmont Center fail-safe.
The other--actually proposed in the 2004 Program for Mass Transportation--is extending the 71 down wires Galen St. to Newton Corner to meet up with the proposed Worcester Line station there...then increase service levels to BRT featuring on the 71. The ridership gain with the Harvard-to-Purple cutover corridor would be large with the envisioned Urban Rail frequencies @ Corner, and that particular wire extension would be extremely cheap because the ex- A Line 600V DC feeder is still live under the street as a 71-to-B-Line power interconnect, and said feeder cable was recently refurbbed by the T. You literally just pay for the pole-and-wire hardware, then plug it back in...no other infrastructure required. You could then *study* whether that's enough in-wire charging range off the Galen wires to BEB the 57 with a corresponding charging pad at Kenmore busway. Think the wire charging range may end up a little inadequate for this one (whereas the ^above^ scenarios with BEB'ing the 77, 75, and 74 are probably fail-safe)...but you'd be in the ballpark enough to give it a look-see. Maybe the combination of Galen wires + a Kenmore busway quick charging pad ends up enough to make the 57 BEB'able.
Bottom line: ripping down the wires is literally insane. The in-wire charging tech not only exists but is battle-proven, inoculates against all of the shortcomings where total-wireless BEB's are still a little dodgy on range in a Northeastern climate, and arguably provides a superior jumping-off point for wholesale BEB adoption with rather than without. If the T were interested in following best practices they'd be aiming to
leverage, not destroy, the TT network for one more 25-year infrastructure maintenance cycle because the resulting BEB buildout will be better with that springboard. But nope, we're getting "Wires iz icky-poo becauz reasonz" cognitive dissonance. Maybe Pollack's successor will be slightly less regressive about that than Pollack was, but I doubt that's enough. Internally the whole agency seems to have a real hate-boner for their OCS staff and that's driving decisions that are shaping up to be regressive-as-hell for the overall goal.
