Reasonable Transit Pitches
My initial impulse would be to ask if there is enough capacity/tracks to pull that off, sharing with Amtrak as well.
Assuming Amtrak's usual level of dispatching competence and that they actually get the center passing tracks they want (alright, to be fair, these are both pretty big assumptions) - it's doable. It's most likely going to require a lot of ~5 minute layovers at Providence and T.F. Green for commuter trains, but it's doable.
If RIDOT is preparing for this, as has come up numerous times on the board, they ought to take advantage of the luxury of starting their service from scratch. They should skip the diesels and order some M8 EMUs just like those Connecticut/Metro North has under construction. Their whole route is electrified. They could buy power from Amtrak and do better for air quality. Plus they would have common equipment that is compatible with NY and CT.
I'm assuming (really, hoping) that this is the plan, but I wouldn't be shocked to find out that RIDOT's just going to repaint the bilevels it "owns" in the MBCR rolling stock pool and call it good enough.
But you know, I wouldn't complain overly much (no, really, I wouldn't!) if RIDOT chose to buy some HHP-8s or similar and whatever 110/125mph rated coaches they could get their hands on and ran those instead.
If RIDOt built the Woonsocket line , and then made it Woonsocket to Kingston Service I would have no problem with them buying M8's but as it stands now with the stations they have and line they have it would be a waste.
No. They will never do that. Unlike an upstart CR agency building all-new lock/stock on some freight corridor RIDOT is not jumping into this alone as an upstart. It's a mature, recently modernized Amtrak and MBTA corridor with 3 mature existing stations even before the T.F. Green and Wickford builds. They're doing it as a secondary party glomming onto the T's and (mostly) Amtrak's handiwork, building their infill stations and paying their share for the track capacity upgrades that benefit Amtrak. RIDOT's small...it's a lightweight. They are not nearly big enough to start at the ground floor and commit billions at once to stations/rolling stock/ops and meticulous launch planning, and the NEC is a fast-moving target that won't sit and wait while a novice partner tries to figure shit out. They're able to move relatively fast on this build and keep their total costs in the mid-nine figures instead of billions because nothing more is required of them than to add their stations and pay Amtrak for the capacity enhancement that'll let manage the traffic. They don't run the railroad (yet...and not for a very long time). They give the existing railroad more places to go. None of this would be happening at all if it required any more planning scope from meager little RIDOT than that.
Hell, even the Providence-Woonsocket CR proposal only has legs because of how little extra they have to sink into a P&W freight line that's already 60 MPH speed and immaculately well-maintained. Signal system + 3 stations are all they have to go in for. Ops...gloms off the same pool.
It's not like those M8 EMU's would even exist if CTDOT were independent all this time. They tether off the Metro North with a similar cross-state compact. Their EMU's are an evolved design off the same general model--numbering in the thousands--used across Long Island RR and Metro North since the early-70's. EMU's are only coming outside the MNRR district to Shore Line East because buying 425 of them at once--in one order and one pool for everyone--is a hell of a lot cheaper than buying a custom order of 30 any-cars for just the outside-MTA SLE service. And there wouldn't be an SLE service at all if the various second- and thirdhand diesel equipment (absolutely zero of it purchased new) couldn't share yard and shop space with MNRR in New Haven. It glommed onto an evolved corridor just like RIDOT is attempting. RIDOT's arguably got it easier than SLE ever did because the MNRR charter does have major out-of-district restrictions that make it nearly impossible to share labor and made it very contentious to even share the M8 order. Whereas the T doesn't have to jump through any loopholes to expand its mercenary reach. It's actually a lot harder for them to add new service inside MA when district boundaries and the charter come into play.
"From scratch" is overrated. There's no reason to start at literal "scratch" when there are other resources to give them a leg up. The T and MNRR themselves didn't start from scratch. The T was just a blank-check writer subsidizing private RR's for its first dozen years. Then it got control of the physical plant and started refreshing it all-'homegrown' with upgrades and new rolling stock, but still had to pay old landlord Boston & Maine to run it for them for another dozen years because they didn't know how. MNRR lasted even longer as a blank-check writer...they're only now celebrating their 30th year of independence from Conrail.
As for electrics, yes, that's a dilemma. Both what kind of vehicles, how many, and when they buy them. But either them or us get electrics way sooner if it's a pool order spun from the existing T/RIDOT agreement. Neither of them will get it if they're paying alone. And RIDOT most certainly would not be starting before 2020 if it had to make the rolling stock purchasing decision by itself. One line is not nearly enough economy of scale to afford the price premium for a specialty order of like 5 electric locos or 30 EMU's for just one party in just one paint job. They'd have to buy used...very, very used. Like SLE did when it debuted 23 years ago with an all-1940's cast of thirdhand rolling stock that's now been upgraded...by one whole hand to early-90's retreads.
I guarantee you 10 out of 10 people will not care one whit if a T-logoed, purple-painted HSP-46 diesel hauling a mix of Rotem and Kawasaki bi-levels is the first thing that pulls into Westerly station on Day 1. RIDOT cares that this happens before 2020 and with a nicely flush daily schedule right out the gate. It does not care one whit what the rolling stock is as long as it's reliable, or whose paint job is on it. That's a decision they can make predicated on the needs for the whole Greater-MBCR NEC equipment pool...when that pool finally does reach the deep end.
Is there any particular reason the MBCR/RIDOT/both can't buy five of the soon-retiring and very dated AEM-7s from Amtrak and slap a bunch of bilevels on the back of those while we work through figuring out what/when to buy a full fleet of electrics/EMUs?
I agree with you inasfar as RIDOT (and 10 out of 10 people on the second train into/out of Westerly) don't care about what the Year 1 rolling stock is provided it's reliable - but the problem is, I think that Amtrak does care and Amtrak absolutely wants less diesel locos running on the NEC, not more of them. One of the key requirements to increasing intercity Regional/Express service on the NEC is going to be boosting speeds for the commuter agencies on the shared sections of the line - certainly, at least, on the stretch between Kingston and T.F. Green where the Acela already hits 150 and soon will be hitting 165, and where it doesn't make sense to fully four-track.
If we were on track to start up service in 2015, yeah, it'd likely start with diesels - but we're on track for a 2020 start date, and I think the reckoning on going electric is coming well before the RIDOT trains do.
Track map on p. 79 of the NEC Infrastructure Master Plan: http://www.amtrak.com/ccurl/870/270/Northeast-Corridor-Infrastructure-Master-Plan.pdf
Yes. Third track will be continuous from Pawtucket to T.F. Green and all stations in RI (including the more recent Pawtucket renderings not captured in that infrastructure doc). And all stops south of Providence to Wickford will get additional turnouts for 4 total tracks: 2 outer platform tracks + 2 inner express tracks. Kingston and Westerly get 3 tracks. And then all that extra passing track work in MA at Sharon, Mansfield, and S. Attleboro.
Funding sequence may vary, but they already got the hardest part south of Providence done with the FRIP track work tied to the Green and Wickford builds, and will have the second-hardest part done when the FRIP track gets rehabbed north to Pawtucket. The rest is just adding platforms and turnouts on empty space.
Shitload of capacity. Probably more than anybody can feasibly fill up given that it's the CT Shoreline and north of Canton Jct. that set the capacity limit for 2-1/2 states' worth of NEC.
Pool service. But the HSP-46 locos, the Rotem bi-levels, and the older-make Kawasaki bi-levels that are now being put through their mid-life rebuilds will all be rated for 90 MPH in revenue service. The RIDOT influence may exert itself in sending most of that higher-speed equipment to the NEC. If they exercise the escalator order on the Rotem contract to a full 150 cars and rebuild the K cars there'll be more 90 MPH-rated coaches on the system than sub-90.
Yeah, electrics better. EMU's better still. But at commuter rail station spacing speed limit just doesn't matter much because the trains spend so much of their time in motion either accelerating or decelerating. 90 helps a little bit on those long Sharon-Mansfield, Mansfield-Attleboro, Wickford-Kingston straightaways. But nowhere else does the train really have enough time to get up to that speed before it's ready to stop again. MARC's Penn Line down in Maryland has HHP-8 electrics and coaches all rated 125 MPH...and it still never tops 90 because of the station spacing. Honestly, the HSP-46's having a third more horsepower than the other wimpy pieces of diesel-belching junk in the current fleet makes 'em start so much faster that'll make more difference than top cruising speed.
Amtrak is putting its 15 HHP-8's up for sale when its new electrics are rolled out. They're only 14 years old and don't have much wear and tear on them. But I doubt those are going to be much sought-after because their reliability is pretty lousy. Not lemon-lousy, but temperamental and generally disappointing. Them and the Acelas coming from the same shit-sandwich car order has pretty much soured Amtrak on Bombardier forever. MARC will probably pick up a few so it can retire its older-model electrics and have a uniform fleet. SEPTA might pick up a few because they only bust out the push-pulls a few hours a day for rush-hour expresses and otherwise run all-EMU. But they'd be an unwise choice for an operator that had no prior experience with electrics.
Probably gonna have to be an all-new/post-2020 purchase decision for them, seeing as how the HHP's are the only used electric vehicles on the market that aren't well past expiration date. Amtrak's AEM-7's have giant forks sticking out their backs (and, lately, more smoke and flames). Those things were bulletproof in their day, but much like the T's once-bulletproof F40's have been pushed about 8 years too long and are falling apart. NJ Transit's mothballed ALP-44's are too expensive to rebuild because of too many old-generation components. And there's no such thing as a secondhand EMU market in this country.
The HHP-8s break down alot and catch fire , you can have our ALP44s but they can't pull double deckers....
The ALP-44's are basically just a second, later production run of the AEM-7 by a different company that bought out the original design. Minor refresh at most. The fact that they're only 20 years old and NJ Transit managed to price out an all-new order at cheaper than what it would cost to rehab probably says all it needs to about the shelf life of 1978's bleeding-edge train design.
Unfortunately that's the state of the electrics aftermarket. No easy answers. Or in the case of the HHP-8's, a whole lot of caveat emptor.
Just got back from SF, and I must say MUNI has done some amazing things with streetcars. It's like if the Green Line were actually reasonably fast! Two things really do it: (1) The whole system is proof of payment. Board all doors at all times. (2) Signal priority! When the train pulls up to an intersection, it rarely has to wait long. At one point where the train I was on has to make a left turn, the next phase in the cycle will always be for the train, regardless of what phase was last.
And for most of the line I was on, the N (not sure about the others), it ran in the street, and streets that were at least if not narrower than Centre St in JP. This included one and two car trains just like the Green Line. It actually worked surprisingly well. Traffic did not get all backed up, and remarkably drivers behaved very well around the train (well drivers in general were much better behaved in SF compared to Boston). For handicapped accessibility, some stations had high level platform islands that the trains could pull up to. But in most cases, you just stepped into and out of the street to board the train. (All the trains are high level cars.)
Oh and another cool thing: The underground stations have high level platforms, and the steps actually come up to be level with the floor of the train once you go underground. Once you go above-ground, the operator presses a button to lower the steps on the side you are to enter/exit. So cool!
The Market St. line has those high platforms in the road median too. Street-running track between stops...curb juts and a concrete center island with side platforms and that mini-high at each stop. They just take parking at an intersection to fit it all in a uniform road width. And these platforms are dual-use with MUNI's TT's stopping at the same platforms, so it's a doubly efficient dual-mode setup. Very smooth and fluid operation. We could totally do that here if provincial Boston were capable of prying the required half-dozen parking spaces at each stop and weaning itself off its addiction to new-installation left-turn lanes at every goddamn light.
Granted, SF's street grid has a bit more order to it than our pure chaos. But it's total myth that trolleys can't coexist in mixed traffic on narrow streets with modern traffic levels. They're the governing vehicles on the road; they set the tone for everything else and condition their own traffic enforcement simply by being there and being the alpha dog on the street. Boston's problem with street-running is that BTD is such a corrupt fiefdom that double-parkers and delivery trucks are the institutionally annointed and protected-upon-high alpha dogs of the road. That's a personnel issue with those glorified BTD mall cops, not a traffic engineering issue. Personnel reform on the enforcement can make all manner of Yellow Line routes run much better without spending a cent in capital investment. And of course we've got totally ready-and-waiting signal priority infrastructure on 2 of 3 GL reservation branches that they refuse to use.
MUNI's TT network also has signal priority since it's a very large installation (rubber-tired traction power beats the shit out of diesel buses at steep grades, and beats trolleys uphill where wheel slip makes uphill acceleration painfully slow). And they have onboard batteries for short off-wire excursions since the lines usually run a few blocks parallel to each other. They simply cut over to a parallel street with no schedule disruption when there's an accident or road work.
MUNI's hardly anyone's idea of a supremely well-run transit agency. They've got their own maddening institutional quirks and Green Line-esque 19th century design limitations on the Metro. But it's almost painful how dysfunctional-to-outright-paralysis the Green Line is after riding SF's only mildly addled LRT system with its exponentially more orderly rubber-tire transfers.
Oh yeah the TT network was awesome too. So clean and quiet. Oh but the wires are so ugly! LOL. I think the wires are beautiful. Shows they actually care about transit. And there were express routes on many bus lines. Imagine that! Boston really needs to get it's act together...
Oh and the historic streetcars! Maybe it's just the transit geek in me but riding a 100 year old Italian streetcar followed by a 1950s Boston PCC in actual service in a major city was just amazing! I'd love to get some old streetcars running between North Station and South Station on the Surface Artery. Would be great for tourists and locals.
I never managed to find the Boston PCC representative :(
Technically they're not historic and the M isn't a heritage line because of the regular-service continuity down there. Old-timey paint job aside, our PCC's are considered "modern-day" vehicles whose only distinction has been their freakishly long tenure in daily service. Hell, Valley Rd. and its un-modifiable steep staircase is the only stop that got granted a permanent ADA exemption. The rest of them had to get the new mini-high ramps during the line closure a few years back. There's nothing beyond age and continuity giving the line any sort of historical specialness, which is why the PCC's were able to get significantly modded for air conditioning a couple years ago and are going to be the test lab for future Green Line CBTC signal tech.
The only other old-but-not-historic PCC operation that compares are SEPTA's PCC II's, which are little more than old PCC shells plopped on top of all-new guts with built-in wheelchair lifts and thus not historic in any way. And the Newark City Subway's PCC operation that lasted until they were finally replaced in the early 2000's. Those things were rebuilt umpteen times and ran on modern pantographs instead of trolley poles. Some of those went to heritage lines, but a mothballed reserve fleet still stored in Newark is slated to go right back into "modern" service on Hudson-Bergen Light Rail's proposed Bayonne Ocean Terminal shuttle spur.
I meant in SF. Though I believe it's not necessarily from Boston anyway, just painted in the color scheme.
The thing I really like about Muni Metro is that it doesn't look as decrepit and unkempt as the Green Line. Stations are well-lit and look like they spent money on quality (versus the Arlington and Copley renovations that are half-baked at best). Regarding the trains, obviously a lot of the wear and tear we see is vastly different because of our harsh winters, but still. That's no excuse for the absolute abominable state most of the 7s are in - paint chipping, rust showing, interiors that haven't been looked at in years (decades?) - it's disgusting.
I found that to actually be the most off-putting - different strokes for different folks, as it were. :) I guess it's a nice tourist draw but if I had to use one of those old rattling things that belongs at a museum everyday I'd probably go crazy!
MUNI doesn't actually maintain any of those cars itself; it only operates and insures them. They partner with the Market Street Railway nonprofit, which runs the SF Railway Museum and has a restoration shop downtown with a spur onto the F Market St. trackage where they have volunteers restore and maintain the vehicles. It's underwritten by private donations from some big business heavy-hitters in town, and they trawl railway museums and collections around the world to try to acquire new cars. It really is a model example of a public-private partnership hitting a grand slam. Ever since the Market & Wharves line debuted in '95 it's more than doubled the ridership of the bus that came before it. They're extending it at the north end to the Maritime Museum and at the south end to hook up to and alt-route down the Metro's brand new Third Ave. line. It's hardly a novelty line today with the general ridership it draws, but when the new connections open it'll pretty much be a system unto itself augmenting a couple flanks of the Metro.
MUNI has no fear about operating those things. A PCC and something of recent vintage like a Type 7 share so much common lineage the controls are virtually the same and--save for the computers--the instruction manual is virtually the same. Some of the stuff pre-dating the PCC's can require special handling, but anything PCC-derived and post-1940 is more or less a "modern" vehicle under the hood with modern construction and suspension. The vintage equipment is so simple to maintain compared to stuff today that some volunteer in a garage who knows what they're doing can pretty much play home mechanic with a secondhand parts supply and keep 'em running forever. Simplicity's why makes like the PCC are still in use by the hundreds worldwide. MUNI's operators like driving those things more than they do the Metro's new (not as bad as ours, but still mediocre) Bredas...and most definitely their old identical-to-ours Boeing pieces o' crap.
If there were any institutional will in Boston to do a historic line down the Greenway or something, possibly hooking into the Green Line at the disused Haymarket portal and looping at GC/Brattle Loop under re-installed pantograph/pole dual-mode overhead on the shared subway track, there's a golden public-private partnership opportunity with Maine's Seashore Trolley Museum. The T and its predecessors have had a longstanding relationship with them donating preserved and operating examples of nearly every streetcar and heavy rail vehicle ever used on the system. But it's strictly been an equipment-and-expertise donation thing with no active involvement (witness the two historic cars, leased from Seashore, just rotting away behind the fence at Boylston). Seashore goes it alone as a total skunkworks operation and survives by having a pretty robust roster of volunteers.
If City Hall and the BRA could take the reins on this and line up some heavy-hitter business donations so Seashore not only could keep the cars sorta operable but actually give 'em nice paint jobs, like-new livery, and maintained to prime operating condition...there's a humongous roster of operable equipment they could rotate down to Boston on flatbed trucks and run on a downtown historic line. It's easily one of the largest trolley collections in the country. They've got 34 different trolleys in their collection from Boston and the former suburban streetcar companies in the inner 'burbs, some of them dating back to the first electric lines in the 1880's and many of them still operating. They've got representatives of every single permutation of MTA/MBTA PCC's, several Type 5's and a couple Type 2's, the old center-entrance cars, a few of the first car types that ever used the subway, and a recently donated Boeing. Plus a bunch from other New England systems. Maybe have a permanent PCC backbone since those are the most reliable and comfortable for general transit and weekday service, and then bust out the true antiques on in-season weekends.
The MUNI/Market St. Rwy public-private template could easily work here in a big way. It's just total lack of political will at calcified City Hall + BRA and a transit agency whose motto is "Don't do anything ever" when it comes to transit inside 495.
Yup, exactly. But I think we see different meanings in this. The fact that it is fully modernized, electrified, and that there are pre-existing stations is a huge benefit for them. Westerly, Kingston, Wickford, TF Green, and Providence will be be ready before RIDOT gets near this. They could, in theory, plunk some EMUs into the pre-existing system with few other capital costs. Amtrak electricity, Amtrak dispatching. The EMU has the benefit of being scalable. I don't think that RI will be at a point where it needs a 5 or 6 car set like an MBTA. They may only be running 2 or 4 cars. A big ol' 20 year old used diesel dragging around half empty cars is inefficient and out of scale for where I guess they will need to be demand wise. Plus, building a purpose built maintenance facility for electrics only from the get-go will be cost effective in the long run instead of a diesel facility to retrofit later.
They wouldn't need billions for this. Later, they could drop in the Pawtucket/Central Falls station for relatively short money. If they could get onto an existing EMU order for a few more at a the same price, one assumes that Kawasaki would be pleased. Keeping the factory running without retooling and building a standard product is more profitable than starting up a new order/procurement.
The Woonsocket line is a bigger prospect but again, the demand seems unlikely to justify a big 'ol diesel dragging some half empty cars. If they can design a service commensurate with demand, they will be better off in the long run. It seems to be about 15 miles from where the line leaves the NEC to Woonsocket. I don't know if you could even electrify it given that it is an active freight line. Even if electrifying costs $10 million/mile and stations are $10-$20 million you are still less than a typical Mass. megaproject.
On a semi-related note...
Without fail, every morning, I pass by several people sprawled out over two seats, fast asleep, when I board Amtrak Regional #66. That's understandable, after all, it is the overnight train.
Now I know it's simply too much to ask for a new train that leaves NYP at 3:45 or 4:00 AM and arrives in Boston at 8:00 AM so that the overnight train doesn't have to double-serve as the morning commute train and hang around for excessive layovers in New York, New Haven and Providence to make the morning commute schedule work, allowing it to swing a 7:15 or even 7:00 AM arrival instead.
But is it really too much to ask for to stick one or three of the new sleeper cars on the front of this train? Come on. There's clearly an unmet demand for them.
This is a fantastic idea, and would be so easy to achieve. I think Mattapan quality PCCs for the bulk of things, and then supplement just with cars that actually saw service within the current MBTA catchment area. Easy, low cost, and useful, so it will never happen.
No, it really doesn't work that way. Rolling stock is a massive, massive up-front capital cost. Without a pre-existing agency to buy cars in lots of 50-100 at a time and power at 20-40 at a time the economy of scale for new equipment is cost-prohibitive. For anyone. Especially when it comes to EMU's. The M8's cost $2.3M per car for a whopping 405 cars, with a still-unexercised option for 25 more. Plus nearly a billion extra in support costs to modernize the New Haven Line shops for them. If somebody were placing a one-time order for like 20 of them in isolation for just SLE or just South County CR they'd probably cost almost double per car because of the infrastructure and labor required at the factory for a short order. The MTA/CTDOT are getting a *lower* price point for keeping the Kawasaki factory equipped and staffed for 5 whole years to build these things. It's much the same for SEPTA's Silverliner V's...$2.3M for 120 Rotem EMU's, although that price has significantly sailed on them with all the teething problems those cars have had.
RIDOT is not big enough to swing that. There is also no facility east of New Haven capable of maintaining EMU's and no yard east of New Haven save for overstuffed Southampton that has existing overhead wires. So that's a half-bil for equipping the yards and building a maint facility, plus over $300M to build a pretty small EMU fleet, plus labor costs for hiring people out-of-state who know how to maintain those things. And, of course, there are no secondhand EMU's...the retiring M2/4/6's and Silverliner III's and in such bad shape they're barely operable, and cannot be rebuilt one more time because the original builders and design holders went out of business 25 years ago.
And if we're talking push-pull, there's also no acceptable vehicles on the aftermarket with the AEM-7's and ALP-44's completely shot and the HHP-8's very problematic without expert maintenance (i.e. Amtrak outsourcing). Price point for ordering only like 5 new ones is similarly extreme. That's why Amtrak decided a total 100% replacement of its whole electric push-pull power was cheaper than just replacing the AEM-7's and why NJ Transit did a wholesale replacement with ALP-46's. We don't, BTW, have enough time to place a supplemental order for Amtrak's new Sprinter locos before that factory shuts down and moves on in 1-1/2 years.
This is why it took SLE 23 years and waiting to get its first (still pending) contingent of new equipment. They went with 50-year-old beaters, convinced Amtrak to ADA and expand the existing Regional stops on the Shoreline, reopened a couple single low-platform shuttered ex-Amtrak stops in as-is condition with IOU's to ADA and double-platform them later (construction still underway at the last couple), and ran a cheap-cheap barebones operation for its first 10 years until the ridership supported wholesale makeover of all stops, better secondhand equipment, and extension to New London. Nobody can afford to spend that much in up-front capital cost for solo service-and-support on such a small fleet. They always end up shopping around for good-condition used coaches and diesels, because they're cheap. It's money they can't spend building the stations or getting the support structure in-place. It's doubly problematic for RIDOT because they are much smaller than CTDOT and have no in-state passenger rail facilities, labor, and fare collection system to support.
Tethering off the T is the only way they can do this. They already are full partners on a pool fleet that's getting modern reinforcements; they already get their whole maintenance done up in Boston; they already have a large modern diesel layover in Pawtucket that'll support expansion; and they already have a whole back-office fare collection system (itself a hugely expensive undertaking) to piggyback on. They ONLY have to spend on stations, pony up cash to Amtrak to build the extra tracks, and up their subsidy share to the T. It's already underway with T.F. Green and Wickford. And this is the only way both states will ever achieve get an economy of scale to buy some electrics...if they can pool the order with the T and if the T can partner to expand the existing Southampton electric facility to share with Amtrak (which means push-pull's more likely than EMU's, unless they can also swing electrifying the Fairmount in a package and get Readville wired for storage).
Not that simple. For one, the M8 order is drawing down in 2014. And the Silverliner order is already done (which is why Rotem's finally starting to pump out the T's new bi-levels in quantity). There's no way anyone here has the money to make a purchasing decision before the M8's are done and the factory shuts down or moves on to other things. And an order here would be somewhat different because our EMU's wouldn't need guts for third rail power or two types of overhead voltage, and would probably go for a larger carbody because we don't have the extreme height restrictions of a Grand Central or Penn. It would on labor costs push it to new-order unit cost with poor economy of scale for a pretty small order.
Our chance to glom off somebody else's order will probably come when NJ Transit replaces its ancient Arrows. And they are thinking of going with a wild new, never before done bi-level power car design where 1 EMU unit pulls two off-shelf bi-level coaches (i.e. something like a 7-car train would be power car + 2 coaches + power car + 2 coaches + power car). That might be a 2020 option if they go joint-order. But RI/MA's would still be a different carbody height because NJT has to do very cramped shorter bi's to get into Penn. And Fairmount electrification probably has to be in the picture to make the unit cost and cost of retrofitting Readville for storage worth it.
Pawtucket's not short money, BTW. Tons of track work required to the freight/FRIP track Providence-Central Falls to get it up to par with the Providence-Wickford upgrades. Plus major interlocking reconfiguration near the P&W freight yard to turn it into a revenue track. The whole Central Falls-Wickford length of it is un-electrified, so tack on that cost whenever we switch from diesel to electric. And since it's such a major transfer point for RIPTA buses it's going to be a significant-size station. Easily their most expensive build after T.F. Green, but obviously very very worth it for the ridership and overlapping services.
Woonsocket's really not that bad. Historic Woonsocket station already exists in preserved state, so cost of a modern build is modest. Only 2 other intermediate stops required, and since it's a mostly single-track freight clearance route you're only talking single mini-high platforms. There's a small yard past Woonsocket station that P&W rarely uses that can be repurposed as a layover. And the line doesn't need double-tracking--just 1 or 2 passing sidings--until they start thinking about going all the way to Worcester. Their (2009?) feasibility study priced it out pretty nice. Little in the way of track upgrades because the existing 60 MPH welded rail will suffice for the short distance and curves, and all grade crossings have existing full protection. Just requires the signal system, which might be $60-80M for the relatively short distance. Their proposed service pattern for it was Woonsocket-Wickford, which is why all the stations down there will get 2 local + 2 passing tracks while Kingston and Westerly will be smaller. As that's the heart of the ridership market it's a good double-up of coverage south of where Providence Line service terminates (likely cut back to T.F. Green when all else is up and running).
It's second priority, but good value-for-money. And P&W is 100% onboard for it.
