Yes, diesel mode, and for now, given low oil prices, it is very hard to make the case that electrification adds a benefit worth the cost, and even hard to make pure "CO2" case: the extra environmental costs of manufacturing all that electrical equipment is probably greater than 20 years worth of operating benefits.Also wanted to chime in: read a bit about this, and not sure if it has been discussed, but as far as I can tell it looks like the dual mode buses will be running on diesel for this? Would it really be that expensive to string up some catenary for electrified service ? I would think it could also be done in a way to easily add electrified service onto the CR side, too.
Bus electrification (which takes two wires, hot and neutral, and need not be constant tension) is sufficiently different from train electrification that I don't think there's any short term consideration between the bus side and the train side other than they stay far enough out of each other's way.
Here's my "sorry if this has been discussed" question: how is the Silver Line Bus Fleet doing in terms of: overhauls and new procurement?
Ah, I was thinking more along the lines that the supporting poles/etc could be shared (with the CR side "empty") in some fashion. Probably wouldn't work now that I think about it given height differences. I do think electrification is the way forward though - gas prices won't stay this low forever, and it gives the beneifits of reducing noise and CO2 in the immediate area - not even taking into account the CO2 used to create the wires/etc, there is still going to be CO2 created to generate the power itself. I guess I would just see it as a more permanent investment in the line - kind of like the trackless trolleys over in Watertown. Plus it would give me hope that maybe one day the Silverline could be converted to the true LRV it should have been![]()
Electrification is the way forward. The on-order New Flyer XE60s are pure electric; they don't need any catenary to operate. The most infrastructure they'll need is a quick-charge station at South Station. Not only that, but the option order of XDE60s are supposed to feature larger batteries so they can operate solely on battery power inside the Waterfront tunnels.
Now that would be pretty cool. I would only be considered on the battery's themselves - they can be very costly to replace should they die. If they last as long as the lifespan of the bus, though, should be fine.
Prius batteries are NiCad and have proven durable across an enormous fleet & range of conditions
Lithium batteries (Tesla, Chevy Volt, Nissan Leaf) prefer the same temps as people, meaning they need to be warmed below 30F and cooled above 80F in order to be long-lasting...fortunately if you are willing to include it in the design, temp-management systems are cheap and plentiful (Nissan Leaf has a heater but no cooler (in order to make its $35k price point) so its batteries fail in places like Phoenix AZ)
Either way, moving ions involves inherently less wear and tear than running on explosions.
A small Li-ion fire can be handled like any other combustible fire. For best result use a foam extinguisher, CO2, ABC dry chemical, powdered graphite, copper powder or soda (sodium carbonate). If the fire occurs in an airplane cabin, the FAA instructs flight attendants to use water or soda pop. Water-based products are most readily available and are appropriate since Li-ion contains very little lithium metal that reacts with water. Water also cools the adjacent area and prevents the fire from spreading. Research laboratories and factories also use water to extinguish Li-ion battery fires. Halon is also used as fire suppressant, but this agent may not be sufficient to extinguish a large Li-ion fire in the cargo bay of an aircraft.
A large Li-ion fire, such as in an EV, may need to burn out as water is ineffective. Water with copper material can be used, but this may not be available and is costly for fire halls.
When encountering a fire with a lithium-metal battery, only use a Class D fire extinguisher. Lithium-metal contains plenty of lithium that reacts with water and makes the fire worse. As the number of EVs grows, so must the methods to extinguish such fires.
During a thermal runaway, the high heat of the failing cell inside a battery pack may propagate to the next cells, causing them to become thermally unstable also. A chain reaction can occur in which each cell disintegrates on its own timetable. A pack can thus be destroyed in a few seconds or over several hours as each cell is being consumed. To increase safety, packs should include dividers to protect the failing cell from spreading to the neighboring one. Figure 1 shows a laptop that was damaged by a faulty Li-ion battery.
Prius batteries are NiCad...
So batteries are bad because they can't store very much energy, and they store way less energy than gasoline. But what makes them even worse is that they store a whole lot of energy in a small package and can thus burn or explode. Got it.
You know what else can burn and explode? Tanks of diesel fuel, gasoline, or compressed natural gas. Remember that Bolt Bus that blew up on the Mass Pike last year? Bus fires happen practically every day in this country. Here's one from Monday, and here's another from Wednesday. These aren't even caused by collisions, they just happen when those millions of little explosions under the hood get a bit too carried away. Nobody cares about these stories precisely because they are so commonplace, but if they were caused by batteries I can guarantee that you would have heard about them already. Your Porsche is WAY more likely to blow up than your Tesla, and it'll give you much less time to escape when it does. Just ask Paul Walker.
I'm sure that most people on this board fully understand the limitations of battery technology. But most people ALSO fully understand the limitations of internal combustion technology, and one cannot consider the faults of one propulsion technology without considering the faults of the other.
Sorry, yes. Nickel + typo = NiCad ;-)Prius batteries are NiMH, a completely different chemistry. The new buses will utilize lithium-iron-phosphate (LiFePO4) batteries.
