commuter guy
- Feb 1, 2007
I'm probably in the minority, but I like the look of the Tobin more than the Zakim Bunker Hill bridge.
I'd like to see the Tobin replaced some day, with a bridge that can also accommodate bicycles and pedestrians. Right now the bridge is a huge uncrossable barrier for anyone not in a car (or the #111 bus).
A tunnel could be built along the east side of the existing bridge as an alternative to a new bridge. But if a new bridge is built, I would move it to the more vacant side of Chelsea as shown on this map.
http://maps.google.com/maps/ms?ie=U...42.387441,-71.048176&spn=0.033282,0.0842&z=14
It should be double deck, four lanes each way, 3 lanes general traffic plus a dedicated bus lane each direction, plus a wide pedestrian/bicycle lane alongside the lower deck. The bus lanes would exit/enter Chelsea street in Charlestown on short slip ramps where the Tobin stacked roadways are each at the same level as the street. The tunnels under City Square won't accomodate a bus lane.
Here's a rough pitch for when the Tobin must finally come down one day (a sad day it will surely be...)
https://www.google.com/maps/ms?msid...&ll=42.391262,-71.02541&spn=0.085831,0.181789
Of note is that the 107/Broadway Bridge would be like a normal street (a la Meridian St or Chelsea St bridges) but with bus lanes. I think it should have four "slide away" leafs (Summer St Bridge on the Fort Point, which only has two however, this would slide away in both directions). This is to maximize horizontal clearance and provide unlimited vertical clearance.
The Levritt Loop Ramps would originate/terminate at Rutherford Ave.
I'm thinking of ways to consolidate roads where 60/16/1A meet.
I think the challenge is the high school and residential properties-- that one neighborhood that has 16 on one side and 1 on the other.... Route 1 is barely squeezed through there as it is.
Also-- how would motorists get from 1N to 16W? Two left turns isn't ideal.
