TheRifleman
Banned
- Sep 25, 2008
That is an enlightening statement.
Whats the most important factor in life? TIME.
I sure don't want to spend my TIME sitting in traffic.
We will keep having threads like this until we impose congestion charges.
I have an easy solution to that don't drive places walk or take the T and unless your on a bus and bam you aren't sitting in traffic.
Vancouver BC has built an extensive and attractive (in my opinion) elevated rail system, not monorail but conventional rail, that is obviously a fraction of the cost of tunneling. The only thing stopping that from happening around Boston is provincialism. I mean, there are plenty of wide corridors an elevated structure could be built above without casting excessive shadows on buildings.
Here are a few potential elevated rail routes to access underserved areas.
Are they coming out with innovative transit IDEAS
Building transit has the same issue as building roads:. If you build it they will come. Demand management should be playing a bigger role in the discussion. Put some limits on growth until the infrastructure is in place.
Being from around he NY metro area this stuff never ceases to crack me up. The traffic last month when that garbage truck caught in fire in the tunnel is what I'm used to every day.
I also have little sympathy; I just like traffic on Seaport Blvd doesn't need to exist because of access at B St, soooooo many backups I really are caused my massholes outright refusing to merge. When two lanes drop to one drivers would rather put the other guy into a wall than just loose one car length. This is then further compounded by I'll timed traffic lights.
You are ignoring geometry. If you build it and "they come" from less geometrically efficient means of transport (i.e. an automobile), than you have increased the geometric efficiency of the system and are now able to move more people than before. Keep in mind, traffic jams are caused by geometric inefficiency. Improving geometric efficiency is the answer.
