These comparisons are getting less and less impressive
I was in Inchon recently and even it might be in the running. Pyongyang (I am told) has a much taller skyline than Boston, so probably a good relocation spot for height boosters.It says U.S. in the article. Otherwise we'd also be including Calgary, Edmonton, and then heading over to Europe for London, Moscow, St Petersburg...
Montreal has 1 cheater building considered taller than 678', but in actuality it has a ridiculous side spire that shouldn't count a lick. The roof is 650's and its otherwise tallest is 673'.
Top-Down Construction. I'll bet the guys down there appreciate a roof during the cold months. Or maybe not.
What Goes Up is Also Going Down: Winthrop Square and Garden Garage | High-Profile Monthly
by Laureen Poulakis How deep can we go? The completion of the Big Dig and end of the recession signaled some of the tallest and deepest building proposals in Boston […]www.high-profile.com
Welp the core is finally rising and the columns are around ground level... were gettin there. Pretty soon itll start rising.
Yes, for the rest of the lower levels, that makes sense, but for the core, it seems to me as if that would have to be built from the bottom up. There's a lot of force going into and down that core when this thing gets built. Having it float/be underpinned seems like quite a challenge/nightmare.^^They'll excavate/scoop it out via precision handiwork, pour more slab/s--and continue downward--while building out the columns below grade to their full size.
"The columns below grade are not yet at their full width...."
You can be confident the considerably extensive load bearing structure will be fabricated below grade for some months--
while the super structure above slowly creeps ahead. At some point--the time saving measures will become evident.
Not gonna lie, I still can't believe this is really happening.
