XenForo Update
dunsarelli
New member
I guess I'll get used to it, but I really wish the "Last" button was retained.
statler
Going to be honest here, that's really disappointing.
Edit: One alternative would be to edit thread titles with [PROP] [U/C] [COMP] [CAN]
or use emojis
⚪ = Proposed
⚫ = Under Construction
🔵 = Completed
🔴 = Cancelled
🔷 = Neighborhood or Infill Discussion threads, etc
Edit: Apparently you can't put emojis in the title field. 😕
Edit2: It's an extra step but justin7 pointed out that you can put emojis in the thread title so I think that will work . Thoughts?
tysmith95
To the last request in the Google doc, I don't see the point of the original page with only the logo. Why can't archboston.com or archboston.org just go directly to the form?
statler
Again, disappointing, but looking at other forums I follow, none of them have this feature either. I guess it's just the way things are now. At least we get the thread title in the URL.
Justin7
All of the things marked "Not Possible" are... not not possible. The common term is "won't fix."
stefal
On desktop, yeah. Still hard to figure out what thread you're on on mobile.
datadyne007
Moderator
Staff member
or use emojis
⚪ = Proposed
🔵 = Completed
🔴 = Cancelled
Edit2: It's an extra step but justin7 pointed out that you can put emojis in the tread title so I think that will work . Thoughts?
The alternatives are being considered along with some other ways to potentially show project info. We can absolutely do things within the thread titles. Emoji are actually a really good idea.
"Not possible" was just meant to imply that "post icons" as vBulletin had were not possible. Sorry for the confusion.
To some others:
Also, I set the "not possible" statuses, so attack me, not Ed. Ed has been nothing but helpful in implementing a lot of these requested fixes in a very short timeframe from when the issues were raised.
datadyne007
Moderator
Staff member
Not able to figure out how to post multiple photos from my flick account. I post one photo ok. When I go to add another I can't get it to add to the post. When I use the attach off my desktop the photos are too large and are canceled. Help appreciated. Other than this I'm liking this software. The photos are really sharp.
@BeeLine, can you please send me a DM describing this issue in detail. I'm not familiar with the process you were using to post photos from Flickr, so if you could explain each step you currently do to post photos from your Flickr, I can review with Ed and try to help you out. We definitely want to make sure you can post photos easily! Thanks.
statler
Not really a suggestion per se, but I notice yesterday the Forums - What's New - Members menu bar was 'floating' so it would "follow" you as you scrolled through the thread. It seems fixed to the top of the page today. I'm not sure if it was a bug or an experiment, I actually kind of liked it floating, but I'm fine with it either way.
Data: are you also looking into ways to introduce thread titles on individual posts as well?
Edit: Also please don't think I'm rushing you guys on this stuff. I know it takes time. I'm just throwing things out there as I think of them.
datadyne007
Moderator
Staff member
Re: the menu bar - it is "floating" for me this morning (meaning it is showing as you scroll). Not sure if it was being tinkered with yesterday.
Re: thread titles on posts - My understanding of this is that it would require significant template modification (read: time) as it is not a base component of xenForo. It's a lot of work for a little gain. Thread titles are now in the URLs and the thread title shows on tabs, so I think we're ok. It might take a little getting used to, but that comes with the territory.
stefal
I had to resize my pictures a few days ago before attaching them on this. 4MP seemed to work. If you have windows 10, right click on the photo, then click 'resize.' It's a longer process, but IMO a little quicker than uploading to a third party and linking it on here.
statler
Interesting. My menu bar is still fixed. My work computer sometimes does wonky things to website features so I'll check when I get home.
The title thread thing isn't really a big deal for me as I do most of my aB browsing from a desktop, but I can see it being a bit of a pain point on mobile. But again, I checked other forums and none of them have it on mobile either. 🤷‍♂️
Whatever system you end up going with for project status is going to be A LOT of work upfront as you update all the threads but once that's done it should be smooth sailing. It's too bad you couldn't export the metadata from the old forum somehow.
datadyne007
Moderator
Staff member
I just realized by the 1000 Boylston thread, if the first thing in the first post in a thread is an image, you can see it on hover in the thread listing. We might consider putting a render in each thread that way (we've wanted to do this anyway). That could be a way we could see a preview of a project (desktop only ofc).
johnmcboston
New member
Just realizing I'm not getting my daily email of threads I've subscribed to. Is that a feature that may come back at some point?
In this new scheme, when I watch a thread, what does that mean?
datadyne007
Moderator
Staff member
I didn't know anyone used that feature. If you had it set on vBulletin, then it likely did not carry over. I will look into this functionality with xenForo.
johnmcboston
New member
hmmm. I unwatched and re-watched a thread and it gave me an email option. We'll see what that brings me :)
Justin7
To some others:
Certainly not attacking you or anyone else here. I'm just pointing out that there is a big difference between can't and won't. All of these things can be absolutely be done, which makes "not possible" rather misleading. I don't believe that is intentional and appreciate that you're even taking the time to track these things.
  • "Won't Fix" - Something that EdCorp believes should not be changed or will never be worth the time/money/effort.
  • "Low Priority" - Something that EdCorp doesn't think is worth the time/money/effort at this time.
Again, not attacking, but attempting to provide some insight: I've never worked with xenforo, but judging from experience with similar systems this looks like a very quick and easy edit for anyone who has worked with xenforo templating (5-10 minutes) and I doubt more than an hour or two for someone who hasn't.
George_Apley
Not a Brahmin
Staff member
Would be nice to have the "multi-quote" button back, to quote more than post in a reply.
datadyne007
Moderator
Staff member
You can simply click the reply button on as many posts as you'd like, as "reply" automatically goes to the quick reply at the bottom of the page now instead of a separate reply page. It will function the same way "multi-quote" worked on vB.
