So ... don't hate the material ... hate how it is used. My only point in bring this up in this thread is that I think it is ok to use this material as a contrasting material to that precast/brick and the other precast/brick. I see nothing inappropriate about it and in this case I don't read it as cheap. That is the subjective part and I respect your opinion if it reads that way to you. If you were my client I would go to something else. GFRC, Corrugated Panels, or a contrasting brick (glazed, or different module) might work depending on cost.
I respect the fact that we both have differing, subjective opinions on this.
For me, the problems with Alucobond are:
Approach - Using composite metal paneling with depth (10 Farnsworth St.) can produce impressive results. Using it as flat panels has all of the aesthetic charm of vinyl siding.
In this case, it appears like they either ran out of money, or just slapped it onto those sections of the building as an afterthought because it needed some kind of material to cover that bit. It's incongruous and ugly. Even though it was probably carefully-planned, it gives the
impression of laziness.
Ubiquity - Architects use it as a primary, or contrasting element in a huge percentage of designs we see. Its inclusion often appears forced, with little reason to support it being added except as a reflex. Often, flat panels will be dropped into the middle of a façade where it doesn't really belong to break-up an otherwise OK exterior.
To me, it comes across as a designer trying to spice-up their design with vanilla. Often, it would've been better without it.
Sometimes it's OK to let a building façade be just one thing, or have a continuous pattern of quality materials over a large section. Which brings me to...
Appearance - Flat and featureless are not favorable traits when used over a wide swath of a building's exterior. This again is strictly a matter of opinion. There's something cold and soulless about Alucobond when used in this fashion.
For me, it provokes the same reaction as seeing a gigantic, expensive house wrapped in builder's special siding: I end-up feeling someone said "Well, we have to wrap it in something, I guess."
Persistence - In Boston at least, the design language has evolved very little this century. We're still seeing buildings that could've been constructed during GWB's first or second term. It's like seeing plans from 1978 rolled-out in 1994 - something that most people would find incomprehensible.
Chronic misuse of a design element is not done any favors by the fact we can't seem to break out of a tired cycle of doing the same things the same way over and over again.
