8pm/2am tonight WGBX,What network is it on?
Amazing link. For those who didn't click the link, here are the "NE Special Project Highlights"For the Acela, there's now a good list at the Connect NEC 2035 project site:
Where they seem to say there's about an hour's worth of time to be saved between Boston and NYC, (about half between BOS & NHV and the other half between NHV and NYP)CONNECT NEC 2035 | Northeast Corridor Commission
CONNECT NEC 2035 is a 15-year plan representing the most ambitious reinvestment program in the NEC’s history and a new way of planning: a multi-agency, multi-year, shared action plan guided by a long-term vision. The state governments of the Northeast, the federal government, eight commuter rail...nec-commission.com
- Massachusetts Third Track (Readville to Canton): This project supports additional service in the NE territory by adding a third track between Readville and Canton Junction stations. Eliminating the two-track configuration in the area will mitigate an existing capacity bottleneck for Amtrak and MBTA services.
- Pawtucket/Central Falls Station: The new Pawtucket/Central Falls Station will provide communities located between Providence, RI and Attleboro, MA with access to commuter rail service. This station will provide relief to overcrowded stations in Providence and South Attleboro, while attracting new riders from adjacent residential redevelopment areas that will take advantage of proximity to transit for access to jobs, educational opportunities, and medical options in Boston, MA and Providence, RI.
- Fitter Interlocking: This project will include the construction of a new universal interlocking on SLE in Clinton, CT that will divide a 16-mile interlockingto-interlocking segment (Guilford and View Interlockings) into two shorter segments, improving reliability by allowing single track operation over shorter segments during maintenance with less operational disruption.
- SLE Grade Crossing Elimination Projects: Four of the eleven remaining grade crossings on the NEC will be eliminated, minimizing the risk of train-vehicle collisions and delays caused by grade crossing warning device malfunctions.
- New Haven to Providence Capacity Planning Study: Study of investment options to improve capacity and service performance between New Haven, CT and Providence, RI.
(complete documents here: http://nec-commission.com/connect-nec-2035/#download)CONNECT NEC 2035 (C35) is a 15-year plan representing the most ambitious reinvestment program in the NEC’s history and a new way of planning: a multi-agency, multi-year, shared action plan guided by a long-term vision. The state governments of the Northeast, the federal government, eight commuter rail agencies, and Amtrak worked together through the NEC Commission to develop a detailed and efficient sequencing of infrastructure investment covering 150 projects along the corridor.
Am I imagining things, or did the Acela Is originally have pantograph wings when they were new?Kudos, though, for NJ.com for knowing that a key bit of hardware that has kept Acela II from running at max speed under old wires has been that the pantograph was bouncing and that the solution has been to fit the pantograph arm with wings. As I look at them, they'd actually pull *down* on the pantograph at high speeds (their lift is inverted from an airplane's curve) If this is the final solution it removes the largest barrier (that I know) to widespread fleet deployment (assuming they can produce them at volume).
Not sure about that, but both power cars have the pantographs up, whereas the new Acelas will only be using one pantograph.Am I imagining things, or did the Acela Is originally have pantograph wings when they were new?
Color scheme is terrible. Colors don't match.Late to the game here, but does anyone else agree that these new Acela trains already look dated on the inside?
The track would have to be FRA class 9 to be above 160.What improvements to the NEC are necessary in order for the Acela to run 186 MPH service (in MA, RI, and NJ) with the new Avelia Liberty trains?
