Your description makes a lot of sense. The infrastrucure needs are certainly a consideration. Meanwhile the roll-out of a RI-run in-state commuter rail operation could mitigate that. The plan I understood from you and EGE is that MBTA services to Boston would likely terminate in Providence while RIDOT would serve Providence to Westerly on the NEC, probably with a starter diesel service. That could leave the MA electric infrastructure and locomotive procurement which could - theoretically anyway - be in time to support but not totally alleviate the pain of the phase out of the GPs and F40s.
Still, it seems that the ROI could be compelling. We will need some new locomotives. Fuel will not be cheap forever. Electrics have good performance characteristics and long lifespans. Worcester certainly expands the scope but there is that whole north south rail link thing to consider.
Simply doing the last bits to get Providence + RIDOT going, then electrifying Fairmount + Worcester, puts well over half of the southside's equipment pool on-wire. It scales quickly after the sticker shock of that initial investment.
