Don't build directly over the substation. A deck could be built at the bridge level. A deck does not need to built over a trench. The bridges are the ground plane of the pedestrian city at this area. The new deck gets built over the existing rail yard and makes its pedestrian connection to the two bridges. Once done the bridges no longer look or feel like bridges. It would be a similar situation to Summer street in the fort point area.
You're not making any sense here.
The South Bay Harbor Trail seawall is the ground plane. That's 10 feet above the water level of the Bass River. West Broadway and W. 4th get up about another 5 feet from there before the bridges even start. Both bridges have a hump in the middle...W. 4th's slight, W. Broadway's very steep. The peak is 25 feet about "ground" level and at the tops of the 3rd floor windows on that brick building on Foundry St. that I linked to twice.
To build air rights here means putting something on stilts to the level of the I-93 South Bay main carriageways...one of the biggest eyesores in the city. To carve out a square parcel on top of that means building a deck as wide as South Bay is from the Albany St. southbound onramp to the South Station northbound offramp where it all overhangs W. Broadway. Reinforced many times over so it can support building pilings. Go look up Big Dig costs for South Bay interchange. $1B expense for $500M (or less) in development is not an exaggeration. It would shroud the Bass River, all trails around it, and what little sunlight makes it underneath the interchange on W. 4th and W. Broadway in complete darkness...dividing the neighborhoods that already have a serious divide in the form of the highway. It would plunge the lower three floors of that Foundry St. building into darkness...all before you plunked a structure on top of that 25 ft. tall "deck" to block a couple more floors. The opposition from Southie and South End on either side of the parcel would be withering and relentless.
Get it? That's not ground level. That's as high in the sky as the roof of the brick back half of the Post Office by South Station. That will not get approved. That will not get the consent of any abutters underneath or across the street. That will not get built. That is so expensive to build that by the time you've built the stilts you have blown money equal to one Olympic stadium just to get the property in place to build an Olympic stadium. That is not a rational proposal.
Move on. The acreage at Suffolk Downs, Beacon Park, the Globe headquarters...hell, the NStar wire spool storage yard and employee parking lots on Mass. Ave. at Newmarket Sq. and the garbage strip plazas on Morrissey Blvd...all have more acreage than this on flat terra firma to do as you please without having to invent some billion-dollar Rube Goldberg-designed landfill-on-stilts just to say it's theoretically possible. Target fixation at making a buildable parcel at the single most difficult place to twist and pervert into a buildable parcel isn't going to get Olympic venues built. It's going to waste a lot of time and resources that could go to other Olympic venues. Build the venues, not the very land they sit on.
