Re: Fairmont Line Upgrade
You're right. I meant the stations on each side. As it is now there are only low-level platforms on one side. I don't use it much but don't the trains have to do a crossover to the platform side? I do know that if they want to increase Worcester service they need to deal with these stations. They probably would need to have some triple track sections too if CR is now skipping some of these so they can overtake the DMUs.
If they go with DMUs would they be high level boarding? If the idea is to service the newly built out Fairmount line and South station they would need to be. Somehow they would need to either have a center high level platform plus passing or side platforms. While it may not look like the Yawkey, it would need the elevator tower or a heck of a lot of ramps like other parts of the Worc. line.
The Worcester Line is already double-tracked. Do you mean triple-tracked? That isn't required if you can cross over between the tracks. Nor is a whole set of Yawkey-like Death Star stations. They need high-level and disabled access to meet ADA requirements anyhow - they'll have to rebuild all those stations before 2024 as it is, but all they need is a high, preferably island platform with an elevator and stairway to the overpass above. Yawkey apparently had to be more elaborate because it sits on a curve, which only applies there.
The big DMU-specific station costs are new stations at Beacon Park and Newton Corner, as well as a fair amount of reconfiguration to allow the DMUs to make it to the existing platforms at Riverside. Most of their construction costs here are going to be Federally-mandated whether they add DMUs or not.
