Tangential, but does anyone know if a map or list exists of the CR stations that indicates platform length as well as which ones are full-high, mini-high, or low platform?
No. Generally speaking, if it's a full-high it's a rote 800 ft. (9 cars) long because that's the default Design Standard adopted by the T in the 1980's and enforced by the Mass Architectural Board. With the 3 Amtrak NEC stops in T territory and some South Station platforms being 1050 ft. (12 cars) long because some
Northeast Regionals run that long.
The only permanent full-highs built less than that were either:
-- Built before the adoption of the Design Standards (2: Malden Center and Oak Grove, built in 1975 to Orange Line 400 ft. length because they were explicitly designed for future conversion to an extension of the OL third express track)
-- Have hardship exemptions because of physical blockers. This currently only impacts the North and South Station terminals due to sheer number and spread of platforms (South Station Old Colony platforms are pinned in to 600 ft. by the USPS/Fidelity side of the complex, and several North Station platforms are pinned in to 600-700 ft. by the tight drawbridge approach)
-- Cape Flyer stops (e.g. 400 ft. Wareham Village), built before the service was made permanent so done on a shoestring budget with generally wood materials
There are 2 "temporary" 200 ft. full-highs built on freestanding blocks: Lynn Interim and North Wilmington. But Lynn Interim is obviously an emergency situation, and N. Will has questions about whether it will even be serviced at all in that location (as opposed to the ex-Salem St. stop on the Wildcat Branch) when thru-Haverhill service vacates the Reading Line in the Rail Vision. Both structures have a maximum shelf life of 10-15 years tops.
Obviously they are
trying now to lean very hard into hardship exemptions to cut costs on future full-highs by shorting their length, but to date no shorties have actually been built in the Design Standards era at intermediate regular-service stops with an exemption. Even Lawrence Station, which only has 680 ft. of "active" platform, was fully built with a 120 ft. incomplete paved platform section to the full 800 ft. (the 120 ft. section just needs its platform edging installed, which they just haven't been in any hurry to do).
All mini-highs, permanent or newfangled freestanding temp ones, are 1-car only...so 85-100 ft. tops. Low platforms--on both the mini-high and non-accessible stops--vary by length almost individually because they either predate the Design Standards or were subject to much more lax pre-2005 MAAB regulations for mini-high stops. They built even those stations to 800 ft. when they could, but probably half or more are less than that (and some...mostly non-accessible...stops rounding to truly odd lengths because their construction predates the T altogether).
Obviously on the system map any stop that doesn't have a handicapped symbol on it is completely low-level and non-accessible, so it's fairly easy to tease those out.
