It isn't even close to worth the cost of going that far for the fewer boardings and the cost of the grade separation in Needham. The very fact that you would have to short-turn half your runs to keep 6 cars from being nearly empty off-peak is the proof that the idea fails bad on the HRT mode.
LRT branch to Junction is one of the very cheapest extensions they can do because of the minimal modification (right down to recycling the low platforms), and the one where service and seating levels can be easily controlled to match the all-hours walkup.
OL to Rozzie is slam-dunk and works now. OL to W. Rox is slam-dunk if it comes in tandem with the GL replacement. Crossing Cutler Park to 128 probably isn't worth considering until a later phase IF they can prove with real numbers that the all-day ridership will be there. And I'm not sure they can. OL-GL transfer at Junction will never ever be considered because of the overkill. And total OL displacement with total cost-sink corridor makeover to Heights will never be considered ever...and will do more harm than good because of the off-peak farebox recovery far below what'll float HRT.
This has been studied almost continuously for 70 years, and intensively 30 years ago. They have a pretty solid handle on what ridership is there and what mode is best to handle it. If they never once put out a plan permutation that sent Orange to the other side of 128, it's safe to say there's good reasons why.
Ah, one of my favorite files. I've been looking everywhere for it.
As for OL to Needham... you could still short-turn half the the runs at Forest Hills. And then you're also set up to eventually give Needham full blown service if they take advantage of the OL and add on to their dense main road along the line.
