It's been done here before. The Harvard bus/trackless tunnel used to have simultaneous trolleys and buses until all the Cambridge trolley lines went by the boards in '58. They definitely gakked the Silver Line by not making it light rail, esp. Washington St. The engineers even admit it should've been, but the BRT lobby had the pols' pockets stuffed with cash.
I don't think it makes any sense to lay track in the Transitway until it's somehow joined with the Green Line. Which can't be done with the SL Phase III as designed because it's unbuildable. Digging under streets is too hard for there to be any more downtown subways. The Big Dig proved there's too many undocumented utilities, too many abutters and tight corners, too much landfilled debris under Boston, and too much geological nuttiness with the water table because of glacial-deposit rocky soil. The costs are so extreme it could never be justified again on a FRESH under-street dig (i.e. SL III, not things like the North-South Rail Link under 93 pre-provisioned by the Big Dig).
If they did something like laying an alternate-route Phase III tunnel 1-1/2 blocks under Shawmut Ave. to the Pike from the end of the abandoned Tremont St. tunnel, then under the RR tracks from South End to South Station...it's much more realistic engineering. They already would have to temporarily rip the s*** out of the NEC from Washington St. to South Station to build the half-mile long North-South Rail Link portal tunnel underneath the footprint of the Providence/Worcester tracks. If they combined those two projects and in the same dig dropped a light rail tunnel over the footprint of the RR tunnel to S. Station, it would get Phase III done for billions less time and money. Nowhere near as difficult to dig under well-packed soil on a wide railbed uninterrupted-active for 150 years and undisturbed by underground utility line spaghetti.
Build that and you can ride a trolley straight from downtown to S. Station and the Waterfront, and hop onto an airport bus from the same exact platform in the same exact subway anywhere from SS to the Convention Ctr. Maybe even continue to City Point or Southie--Andrew on a short streetcar jaunt while the Airport buses peel out into the Ted.
Re: subway under the B, BERy was thinking that way back in 1932 when Kenmore station and the B and C portals were built. The B platforms were built high-level with wood covering a hollow deep railbed (since filled in support the Type 7/8's weight) to allow future conversion to heavy rail. The C loop was designed to keep the C a surface trolley looping at Kenmore with cross-platform transfer to the heavy-rail trains. The subway would go to Packards, up Brighton Ave. on the A line route, and eventually angle over onto 2 of the pre-Pike Worcester line's 4 tracks en route out of town. Possibly with a short branch subway from Newton Corner to Watertown that then could go elsewhere cutting onto the Watertown Branch RR ROW. Surface B would've been abandoned from Packards to Chestnut Hill Ave. where it closely paralleled the A and C, and the C would've been extended via CH Ave. to BC.
Same deal when the Huntington Subway was built in '41. They saw it going to Brigham under the reservation, then eventually getting filled in to Brookline Village onto the eventual D line. Unfortunately they ran out of money, had to stop at Northeastern, and had to compromise with Copley Jct. instead of a proper flying junction.
The B or E ROW's are similar subway candidates for the same reason that the NEC has relatively underground-undisturbed existing trackbed to cover under with easyish-engineering and minimal surface disruption. But very short-gap street infills like the 1/3-mile Red-Blue connector and the 1/2-mile Brigham-BV leg are the only viable street-dig exceptions (both also have a less density and fewer engineering challenges than a Chinatown dig). Boston is never getting a 2nd Ave. Subway. Even NYC had to wait 7 decades, billions in funding, and a crisis where the Lexington Ave. line could no longer function without relief to get that megaproject underway. Under much wider, less tightly-abutted, straighter, less-landfilled Manhattan streets vs. Boston's.
Our only viable options for us are existing railbed buries like the B/E and special cases like the N-S Link and its under-railbed approach tunnels. I don't even think the south half of the Urban Ring through Longwood and Roxbury could ever be tunneled as proposed or grade-separated like the above-ground railbed north half. It would have to be streetcar at best, and each half would have to compromise by looping through the existing (perhaps B/E subwayed) Green Line in lieu of a complete circuit. But at least we have that much going for future options, and potential to bulk up with new east-west and (via the Link) north-south trunks.
