Re: Driven By Customer 'Service' Parte Dos
No. They can do this on Blue/Red/Orange because the track circuits that fire the signal system can sense the position of trains by measuring strength of electrical pulses through the running rails. That's how Maverick has had that light-up train board on Blue for over a half-century now. Green can't do that. That relegates them to:
1) Signal repeaters in the subway to maintain GPS underground. Similar to the cellular repeaters they have set up, but varying signal strength is probably gonna make that a glitchy operation they have to test for a long time before going live.
2) RF tags. Same as the tags that trigger the auto-stop announcements, but set to a different radio frequency for position tracking. Reliable and cheap, but it's not 'live' tracking because the train has to pass a transponder to ping its position so the travel times are going to be much more approximate and more likely to be wrong (e.g. if the train has to stop in between RF tags, the calculated timing between tags in obviously going to be inaccurate).
Does GPS work underground?
