Teban54
- Nov 13, 2021
Minor note: During Green Line D branch shutdowns, shuttle buses typically use Beacon St, Park Dr and Brookline Ave, so that they can stop right at Fenway station on Park Dr.True. The problem with Davis is that most shuttles must travel via Clarendon Hill. There's also the 96 bus route to get to Mass Ave. from Davis, but they still have to travel via Alewife Brook Parkway to reach Alewife. Alewife Station isn't really in a good spot to run shuttle buses inbound to Davis, Porter, or Harvard. It's surrounded by heavily trafficked highways and parkways, plus Fresh Pond and other limited left turn routes, to try to get into Cambridge/Somerville/Belmont proper. It's especially true for trying to follow the rail lines into and out of town.
This got me thinking tangently. Take a map of all dedicated ROWs for railways or transitways, and try to run rail replacement shuttle buses for as many railway/transitway ROWs as possible. It also gives a look whether a conversion of a railway ROW into a subway line could eliminate a bus route (result:, very few existing bus routes are able to be scrapped with a rapid transit extension).
Using a blank map of transitway/railway ROWs, and run an assumption that all the inner core ROWs are converted into subway w/ more frequent stations. In the inner core w/ the 1-121 bus routes, it's no big deal to run shuttle buses, but finding a good route to run shuttles close to the railway ROW gets harder once outside of the inner core of Boston.
Map of potential (unverified) shuttle bus routes for all possible railway/transitway ROWs in the inner core Boston area, alongside the Highland Branch, Braintree Branch, and Watertown Branch. Red are the shuttle bus routes. Black are the railway ROWs, and cyan is the subway/transitway ROWs.
Alewife Station sticks out as being one of the worst spots to be running rail replacement shuttle buses. Running shuttle buses to replace a reactivated Watertown Branch subway/metro rail line through Alewife and Porter is very tricky and even worse than the existing Alewife Station as a terminus station, having to travel to Porter and Watertown, instead of Davis.
If a additional station or so were added to the Fairmount Line, then one tried to busitute the entire Fairmount Line, there's not a lot of good shuttle bus routes for the Fairmount Line.
Try this out for yourself, and share the possible results. Find a way to run rail replacement shuttle buses on as many lines as possible within the inner core area of Boston, bonus points if subway/regional rail service is extended to 128 with more frequent stations/stops. Assume any potential (not currently existing) station spot is an "actual" station that needs to be served with rail replacement shuttle buses as close to the station location as possible. These are the maps to base off of (I just cut the ROW off where the T buses stop running, regardless if it's an appropiate place to terminate a rail line or not). For now, assume existing roadway configurations remain in place.
View attachment 33837 View attachment 33838
As for Alewife, I wonder if it's better to run shuttle buses from Porter instead of Davis. However, that will be confusing operationally.
