- Dec 10, 2011
It seems to be engineers are also saying "make it wider". The federal guidelines, which I have yet to see a compelling argument should be ignored, call for a minimum of an 11ft wide path with a minimum 1ft buffer on each side before any fences or barriers.
https://www.fhwa.dot.gov/publications/research/safety/pedbike/05137/05137.pdf
http://imentaraddod.com/wp-content/uploads/2017/07/AASHTO-GBF-4-2012-bicycle.pdf
How about we just leave empty support columns (and spend the money on GLX platform shelters and double-ended access) until we can afford it as wide as bike advocates want?
Right now, the station platforms are leaving blank space for future lengthening, and future "other end" entrances (Gilman*) rather than being built full-length. Maybe the bike bridge sections should be handled the same way: left blank; not blocked, but not built either.
A great case can be made that building it at its current width is somehow long-term-insufficient (and that'd be wasteful if our future selves have to demolish bridge sections and build them wider)
But there's a lot of future proofing on the station thsemselves that could (should?) be done in the GLX that isn't. It strikes me as a priority inversion that we're future-proofing the bike path first.
*Gilman should have two full-service entrances: School St (which it will) and Medford St (which it won't). Instead of extending the station all the way to an entrance from Medford St, they tie it into the nearby path, guaranteeing that the path will be choked with walkers and that thru bikes are gonna bellyache.
https://www.mass.gov/files/documents/2019/02/05/glx_Gilman_Sq_Station_1218.pdf
The "complete" view of this station would have paid the extra to tie the entrance to big, capacious, multi-modal Medford St (better for every mode) not cheaped out on a path that will basically never be appropriate for thru-biking.
If I had to spend $ on being long-term bike friendly, it'd be (have been) on building Gilman's other entrance on Medford St. As it is, we're going to soon have another "victim of success moment and need to tear the path entry out and build it Medford St instead.
