bigpicture7
- May 5, 2016
Pretty gorgeous resto of the old viaduct drawbridge:
Nice! When new concrete is placed alongside old weathered concrete, some integral coloring of the new concrete to match the old would help.
I hope so. A stain applied to the new concrete would help, but I usually prefer integral coloring in the concrete mix.I am expecting that the streaks of discoloration on the concrete mean they'll finish with some kind of power wash that will restore a more uniform patina?
Wow! The lamp posts and archways don't appear to be perfect replicas of the originals (seen at the center of the photo below), but they add a lot.![]()
Was the draw still nominally operable prior to this rehab?
Murphy says the last time the drawbridge was actually raised was sometime in the 1970s.
It's probably been way longer than the 1970's since the machine room was operational enough to do a self-contained raising without excessive staging to help it along. Former Boston Street Railway Association member Paul Joyce did a lot of the photo documentation of the derelict machine room, and he said all river traffic that would've resulted in any regular raisings was defunct by no later than the Korean War. If it was raised at all in the ensuing decades, it was for extreme-special occasions and took time-consuming advance prep to happen.
Track level has been sealed since at least 1976 when the trolley pole -only overhead and its former bridge-opening breakaway section was replaced by new continuous pole + pantograph -compatible overhead in prep for the Boeing LRV's. From that point on it wouldn't have been possible to raise the span without staging a weekend outage to physically cut down the wire and un-bolt a length of rail. Allowances for moving it in any way/shape/form have been gone since the mid-1990's when a fixed drainpipe (easily visible here) was installed across the span.
Note: the posts and catenary arches by the former moving span aren't new. They were added circa-2000. Haven't seen the lamps lit in years, however.
The Fort Point Channel bridges would have been a nice display of engineering, if they had maintained their machinery.
The Congress St bridge lacks its massive counterweight. I can’t believe it’s operable now.
Yeah, but after waiting since 1945 for GLX to happen, a few more months delay to completion doesn't seem bad.View attachment 11740
If you look really closely at this blurry screengrabs I took from the board meeting you can see an estimated Oct 2021 date for the Union Sq branch and a December 2021 date for Medford. Which is somewhat disappointing given all the documents about the Lechmere closure had suggested an 11 month closure ending in May for Lechmere/Science Park.
