Re: Green Line to Medford to start in 2011
I recall the City of Somerville hinting in the past that there were ongoing conversations about working with the state to fund and build the full community path. At GLX meetings up until now, the project team has been quite clear that their work does not include building the full path, only designing it and ensuring their work does not preclude its completion.
In reality what this means is the retaining walls they are building will provide enough room for the new tracks as well as a "path area" on the western/southern side. As I understand it, the retaining walls would sketch the path but GLX would not provide the paving, lighting, ramp rails, to make it complete.
In some instances this is a distinction without a difference. Emergency egresses, for example, double as the path for the new Lechmere, Washington St., and Gilman Square stops. It would be merely the gaps between these areas that would not be "completed path."
I suspect this announcement will be that the state has agreed to complete the full path from Lowell Street to Northpoint. The Cedar Street location makes thematic sense as it is the present terminus. You get the Governor to say, "In five years you will be able to travel from this point to downtown Boston completely by sustainable, safe means." Great TV visual, given the current construction. Even though it is not technically the same project it gives the viewer a sense of activity.
