TheBostonian
- May 25, 2006
I've been giving some thought to the MBTA bus system, possibly in anticipation of a GIS project, and put this on my little website.
http://_________.googlepages.com/keymbtabusroutes
I've heard it mentioned that the MBTA has considered adding a handful of key bus routes to its subway map. In a sense it has done this by adding the Silver Line Washington route to the map, though that is planned to be connected via an exclusive tunnel to the already partially underground Silver Line Waterfront service. It might be time for the MBTA to revisit this idea as one element of a broader plan to promote bus ridership. The recent fare increase and restructuring did away with the subway-only pass, forcing commuters to purchase a subway and bus LinkPass. And subway to bus transfers are now free. The MBTA has a number or routes that run at least every twenty minutes or more frequently even off-peak.
1 - Harvard - Dudley
15 - Kane Sq./Fields Corner - Ruggles
22 - Ashmont - Ruggles
23 - Ashmont - Ruggles
28 - Mattapan - Ruggles
31 - Mattapan - Forest Hills
32 - Wolcott/Cleary - Forest Hills
39 - Forest Hills - Back Bay
43 - Ruggles - Park & Tremont
57 - Watertown - Kenmore
66 - Harvard - Dudley
70 - Cedarwood/Waltham - Central
71 - Watertown - Harvard
73 - Waverly - Harvard
77 - Arlington - Harvard
111 - Broadway/Woodlawn - Haymarket
There are also places where two or more less frequent lines converge, so that a commuter can take one of several lines to get to a particular destination. Examples include the 131/136/137 trio through Main Street Melrose, the eight routes through Dudley, Roxbury Crossing and Ruggles, nine routes between Roslindale and Forest Hills, four or more routes between Alewife and Park Circle, among several other converging lines. The MBTA should changle their nomenclature so that converging routes share the same number. For example, routes 71 and 73 could be just 71 with branches A and B. In the case of the routes through Melrose, there would be one line, say 131, with branches A, B and C. A simplified schedule could then be published that shows the higher frequency of service where the three lines converge, which is through most of Melrose. Then a commuter traveling from many points in Melrose could look at one schedule, rather than the three that apply using the current system. It would be much like the Silver Line Waterfront, with SL1, SL2 and SL3, and the Green Line with its four branches.
The MBTA bus system is underrated and underutilized. The recent elimination of subway-only passes and the introduction of free subway to bus transfers brings the system to a crossroads in which this asset could be exploited by rail and automobile riders who for whatever reason avoid hopping on a bus.
