And I probably would've taken a billion more pics but at that point I got escorted out of the garage by a friendly security guy. I guess my stealth mode wasn't working today.
So back on terra firma...
All their US locations are in the most suburban of locations
Better there than here. As I said in the retail thread, the cure for Boston's fashion ills will not come from the Japanese version of Old Navy.
Sorry, no steel to be seen. It is a 100% cast-in-place concrete tower.
Are they doing 100 CIP because the narrow floor plate? Does CIP offer better rigidity needed at height over that smaller footprint than steel beam construction affixed to a concrete core?
...I know many more guys on the shorter side who would prefer to shop at Uniqlo rather than buy adult shirts that wear like moo moos or shop in kids stores.
UDTX may not provide the level of foot traffic they want for a flagship Boston location
CIP is the preferred structure for condo units since the concrete insulates sound better than steel.
Sorry couldn't resist...
and the ability to gain floors within the overall height limitations. Remember you gain 1 floor every 9 or 10 floors using CIP vs steel.
Looks like you used a DSLR or other non-smartphone camera. Likely someone reported you to security or security saw you on the cams. I work at 33 Arch and have never once had an issue hanging out on the 9th floor of the garage to take pictures, even standing there for upwards of 30 minutes.
^But we will go your bail if needed.
I still consider that a misleading idea. You can do 9' floor to floor with steel plus slab, you can do it with steel in concrete hybrid, and you can do it with straight up CIP concrete.
Minimum heights are still needed. Plumbing from above is still going to set ceilings where they need to be.
Ah ha! The sound isolation makes sense, though I assume that sound transmission between units on the same floor is largely dependent on insulation between the drywall...unless they will be also doing CIP walls between units, too?...
Where does the 1ft difference between CIP and steel come from? Do I-beam floor supports really add that much to loss of vertical habitable space?
You're correct. The sound insulation benefit is between floors due to the concrete slab. You're less likely to hear the loud music of the person above or below you when the structure is concrete. The party walls between units on each floor will still need to have the proper insulation.
In regards to the concrete vs steel with size: In school we were taught that concrete construction allows more usable floor space than steel, both in the horizontal and vertical. The floor-to-floor height can be tightened as well as the sizing of the columns. My notes from a structures lecture said the gain can be up to 1' per floor, but the website I'm about to reference says 2'. The details of steel frames typically involve decking that rests on joists/beams, then beams on girders. This ends up with a thick structural component between floors.
Consider this diagram:
Building Volume of Concrete vs. Steel
10 Story Building
Concrete structures require a smaller footprint and offer more marketable space. It is also worth noting that most commercial construction around the world is done in concrete. Steel is still holding strong in the US.
Refer to: http://www.rc3online.com/advantages.html for more information.
I work in MEP, specifically P/FP. Since Millennium Tower will be a residential tower, the MEP services will likely be distributed vertically in the walls rather than horizontally in the ceiling. This is an industry trend for essentially all new multi-family residential construction. The floor plates/apartment layouts are the same and the plumbing stacks just run straight up and down near the fixtures. For residential construction, you really don't need much room in the ceiling. It's essentially just the structure.
Labs, schools and hospitals are often distributed horizontally, though I have seen requests for hospitals to distribute vertically (the architect had this brilliant idea 2 years into the design... we said "lol, no" since we had essentially piped up the whole damn place horizontally)
