Millennium Tower Boston has a 6'-6" thick mat slab foundation with 24.3 million pounds & 6,000+ cubic yards of concrete. It was the largest continuous concrete pour in the history of Boston.
Under most of downtown Boston is the Cambridge Formation, called Cambridge Argillite (also called Cambridge Slate or Cambridge Mudstone, depending on which geologist you are talking with). The argillite is a slightly metamorphosed, reasonably weak, layered sedimentary rock.
There is bedrock, and then there is bedrock.
http://sanfrancisco.cbslocal.com/20...y-high-rise-millennium-tower-is-sinking-fast/In fact, the Millennium Tower sits on an area of mud-fill. It is not steel-framed, and instead relies on shear walls, columns and beams. The building is anchored over a thick concrete slab and its pilings extend about 80 feet into dense sand, not into the bedrock which lies about 200 feet below street level.
For that reason, the transit authority says it went to considerable expense to protect its high-rise neighbor, before it even broke ground on the Transbay Terminal.
“Aware that the Millennium Tower foundation failed to reach bedrock and was therefore inadequate to support the Tower, the TJPA took the extraordinary step of spending more than $58 million to install an underground buttress between the Millennium Tower and the Transit Center site before the TJPA began its excavation for the new Transit Center,” the statement said, denying any responsibility for the settlement of the Millenneum Tower.
In earthquake-prone Northern California, the sinking is raising major concerns.
I went by there today and noticed what appeared to be a crack in one of the lower floor window panes taped up.
How tacky is that for a new tower that still has yet to open for business. Shame!
Maybe it's sinking?
Boston Millenium Tower Geotechnical Design
"Ground improvement was required because the native bearing soils were previously disturbed below the bottom of the proposed mat foundation. Without ground improvement, the mat foundation would settle beyond tolerable limits. Hayward Baker was able to design and install an auger cast soil replacement prior to excavation and in conjunction with ongoing construction activities with minimal impact to construction schedule. Figure 4 shows Hayward Baker auger cast drill rig during ground improvement operations. Once excavation and ground improvement was completed, construction of the building’s 6-foot thick reinforced concrete mat could begin
For support of the tower crane, Hayward Baker installed 150-ton capacity micro piles extending through the fill, clay and into bedrock with a length of approximately 100 feet. Micro pile installation was performed at night to limit disruption on the project schedule."
For those interested in Boston Millenium Tower's foundation system and how it might compare to SF MT's:
Boston MT's Geotechnical design firm was Hayward Baker. They have an article on all of the site prep, excavation, foundation design (and even tower crane support design):
Is it really that big of a deal? That can happen any time whether this building was open or not.
To your point on the Hancock, there are actually two tuned mass dampers (one on either end) to counteract the twisting motion of the building.
So the first figure bigpicture posted from the website shows an area annotated as "approximate area of ground improvements" that is maybe 1/12 of the total area of the building footprint. Are we sure that these auger castings were placed across the whole foundation, or does it not matter? Sorry for belaboring things...just looking for a little foundation edification.
