NEMA Boston | 399 Congress St. | Seaport
Re: Residences at 399 Congress St (formerly Madison Seaport Hotel)
Don't hate the mockup. A little depth, a nice tone of wood to warm it up, and the right third at least has a pattern to it. They have to save money somewhere. Not a big fan of the blank panel above the center windows. A little articulation there would go a long way. I also think the stone bits could use some horizontal breakup, some string coursing maybe, or else the whole facade could seem too flat. But good enough.
Keep 2/3 of the sampler, and delete the portion on the right.
From the above, I can identify and associate the dark grey panels and the light grey panels with the render. I'm having trouble understanding where the stone tile and wood (arguably the most attractive of the materials) would go though. Those grey panels look downright drab in isolation.
It looks like the stone and wood will go on the ground level. The rest will be generic precast.
At the storefront system along the streetwall?
In that case, the blank metal panel would probably be louver and not as plain at the mockup.
Edit : Snaked by Arborway.
I suspect that some combination of the left two parts of the mockup will constitute the glassy parts of the rendering, which is a little bit unrealistic-looking anyway. It'll end up making the building look more solid, instead of two glass boxes screened by the two colors of gray panels.
Edit: really should wait a bit before responding; see the above two comments.
That would be both a shame and some (intentional) misleading by the mock-up, which appears to emphasize the stone and wood much more than the grey panels. Too early to tell, but perhaps the crap name may be fitting.
The mockup's purpose is to test appearance, durability/weathering and most of all, constructability, to make sure the architect's details work. It has nothing to do with "leading" the public on anything. For a mockup, each element/detail of the facade is constructed, often with smaller proportions, to see how everything fits together.
Steel is now on floor 1/2, tower crane is installed. Interestingly, no concrete core for this one
sorry for the bump......
i didn't realize this was already rising.
is this taking advantage of up/down site prep?
To anyone in here who gets the opportunity of making these kinds of decisions: please choose more of the classy textured stuff on the left.
I'm sure I'm not the only one who is fond of materials like this.
Thanks Beeline!
Apparently this building is called NEMA. I found some renderings that I don't think have been posted here before.
Could someone please explain the ramifications of no concrete core? Every other newer constructed building that I’ve seen come up in the area has used the concrete core approach. Could this be a “good” thing, a “bad” thing, a budget thing? Seems like a rather odd thing, but I could also just be uneducated in that area.
This is a summary of post 9/11 changes to building codes.
* An additional (third) exit stairway for buildings more than 420 feet high.
* An increase of 50 percent in the width of exit stairways in new sprinklered buildings.
* Permitting the use of elevators for occupant evacuation in fires and other emergencies for all buildings, and as an alternative to the required additional exit stairway for buildings more than 420 feet high. Passenger elevators must meet specific criteria to be used for evacuation purposes.
* Hardening of exit stairway and passageway enclosures, and elevator shaft enclosures, in buildings—for all buildings more than 420 feet high, for buildings 75-420 feet high where failure of the enclosure would substantially jeopardize human life, and in essential facilities such as hospitals.
* Separating exit stairway enclosures by a distance not less than 30 feet or not less than one-fourth of the maximum building diagonal, whichever is less. For example, a building with a 50-foot by 50-foot floor plan would have a diagonal of about 70 feet. One-fourth of 70 is 17.5 feet, which would be the minimum distance required between exits (since it is less than 30 feet).
* A minimum of one fire service access elevator for buildings more than 120 feet high.
* Fire service access elevator lobby sizes that are a minimum of 150 square feet in area with sides at least 8 feet long.
* Keeping fire service access elevator lobbies free of storage.
* Greater reliability of sprinklers with a minimum of two water supply risers for each sprinkler zone in buildings more than 420 feet high. Each riser is required to supply sprinklers on alternate floors and will be placed in remotely located stair enclosures.
* Providing minimum structural integrity for framed and bearing wall structures
* A one-hour increase in the fire-resistance rating of structural components and assemblies in buildings more than 420 feet high.
* Explicit adoption of the "structural frame" approach to fire resistance ratings that requires all members of the primary structural frame to have the higher fire resistance rating commonly required for columns. The primary structural frame includes the columns; other structural members including the girders, beams, trusses and spandrels having direct connections to the columns; and bracing members designed to carry gravity loads.
* Broadening the definition of the primary structural frame to include bracing members essential to vertical stability (such as floor systems or cross bracing) whether or not they carry gravity loads.
* Increasing bond strength for fireproofing to nearly three times greater than currently required for buildings 75-420 feet high and seven times greater for buildings more than 420 feet high.
* Field installation requirements for fireproofing to ensure that:
> installation complies with the manufacturer's instructions;
> the substrates (surfaces being fireproofed) are clean and free of any condition that prevents adhesion;
> testing is conducted to demonstrate that required adhesion is maintained for primed, painted or encapsulated steel surfaces; and
> the finished condition of the installed fireproofing, upon complete drying or curing, does not exhibit cracks, voids, spalls, delamination or any exposure of the substrate.
* Special field inspections of fireproofing to ensure that its as-installed thickness, density and bond strength meet specified requirements and that a bonding agent is applied when the bond strength is less than required due to the effect of a primed, painted or encapsulated steel surface. The inspections are to be performed after the rough installation of mechanical, electrical, plumbing, sprinkler and ceiling systems.
* Luminous markings delineating the exit path (including vertical exit enclosures and passageways) in buildings more than 75 feet high to facilitate rapid egress and full building evacuation.
* Broadening the use of luminous markings to identify obstacles, exit doors, exit signs and floor numbers in the exit path in buildings more than 75 feet high.
* Luminous exit path markings in existing buildings more than 75 feet high with the exception of open, unenclosed stairs in historic buildings.
* Increasing the area of the Fire Command Center (the area from which all fire department operations are directed and usually housing the control panel for alarms, sprinklers, etc.) from 96 square feet to 200 square feet with at least one side 10 feet long in buildings more than 75 feet high.
* Approved radio coverage for all buildings for emergency responders within the building based upon the existing coverage level of public safety communications systems at the exterior of the building. Approved coverage includes specific requirements for signal strength, system design, installation and maintenance.
* Installing an emergency responder radio communications system to provide the required level of radio coverage throughout a building. Typical hardwired communications systems would be replaced.
Additional Proposed Changes to U.S. Model Building and Fire Codes
Based on Recommendations from NIST's WTC Towers Investigation
The following are the nine model building and fire code change proposals consistent with the NIST WTC investigation recommendations that were not approved for the 2009 edition of the I-Codes but will be considered for resubmission at a later date after being amended:
Requiring buildings more than 420 feet high to be designed to survive a building contents fire to burnout without more than local failure of the structural frame.
Requiring structures not to suffer a collapse disproportionate to a local initiating failure caused by an accident or incident.
Requiring a risk assessment and acceptable mitigation of risks for buildings more than 420 feet high with an occupant load greater than 5,000; for buildings with an occupant load greater than 10,000; and for buildings determined to be at higher than normal risk.
Requiring use of a new standard for conducting wind tunnel testing.
Requiring installation of stairway communication and monitoring system at every fifth floor of each exit stairway. Also requiring, in buildings more than 75 feet high, a video surveillance system in each exit stairway, elevator lobby, elevator hoistway and elevator machine room to enhance situational awareness of emergency responders.
Requiring fire safety and evacuation plans for all occupancies and buildings where required by the International Fire Code (the International Building Code is more widely adopted across the country than the IFC; this would ensure all situations are covered).
Requiring detailed schematic building plans, including an approved Building Information Card, to be located in fire command centers to show the type of construction, stairway access and pressurization, fuel oil tank and hazardous materials locations, standpipe availability and locations, in addition to typical floor plan and details of the building core, means of egress, elevator locations, fire protection systems, firefighting equipment and fire department access.
Limiting the length of horizontal transfer corridors used to connect a stairwell to 50 feet or less in buildings more than 75 feet high.
Allowing the option to design buildings more than 420 feet high using the ICC Performance Code, instead of the high-rise provisions of the International Building Code. This change will allow the performance-based NIST WTC recommendations to be considered in a holistic manner.
https://www.nist.gov/news-events/ne...code-changes-based-recommendations-nist-world
The concrete core is one way to skin the cat. (Also note with respect to a proposed building on the Greenway, the cost consequences of going from 420 to 600 feet.)
Damn fine response.
cca
Name confirmed: https://www.crescentheights.com/portfolio/nema-boston
Mods, can we please change the name of this thread to: "NEMA Boston | 399 Congress St. | Seaport"
In case others missed it, the developer’s site that is linked also shows that there is also a NEMA-branded apartment tower in San Francisco (37 stories), and one in process of being built in Chicago (76 stories!). Both look a lot better than what we’re getting here, IMO. :(
