Absolutely, Corey. Good ideas. But, this project is bounded by time constraints, and it is difficult to begin fresh once the idea has been put into the model (a site plan was done first). It could be done, but this is sort of a rough draft if you will. The criticism is as important as the project itself.
I would put an intermodal transportation hub of some sort on Marginal, too, but for the same reason have not (time).
The skyline did indeed factor into this design, strongly. You see the 14 story building across from intermed, so that it would peek over that building and be visible. Its more slender appearance gives the visual appearance that intermed itself has a tapered top, from some angles. Then there is the 8 story building featured most prominently in the rendering. The idea there was to give some variation while also peeking above the Student housing.
It is difficult to enhance the skyline where the student housing is, because that building is so long and of a constant height. This area is lower topographically, so a 14 story building wouldn't do too much to block what is there already, especially in light of Intermed. The other option would have been to build tall in the trader Joe's parking area, but although I considered how this would vary the skyline more, it wouldn't produce as strong of a gateway to Marginal way. All very interesting contemplations from a design standpoint. If you are interested in design, I can recommend a few good books (which you may already be familiar with from what I have read in some of your posts). It seems like urban design is so fundamental in some ways that a class is unnecessary. But it sure is fun nonetheless! And we have some interesting discussions. There is a really good article we read (and an associated documentary) on the design of public spaces in NYC. Also, the FBCI is hosting sessions in portland next month, but that is more for professionals (not that you couldn't understand it, but just that it might be tailored more toward working instead of hobby based)....either way I suggest you look into it if you have any interest.
