Equilibria
- May 6, 2007
I still believe that you'd have 10x the ridership on Red -> Fairmount than you would under DMU/EMU/Whatever.
Sure you would! That's not the problem, though...
On a different subject, given the headaches inherent to even the current operation of GJ, could the whole line be trenched, as opposed to just at the intersections? It looks like plenty of lead-up on each end, and the line's so old there can't be anything too crazy under there.
You'd have to duck under the red line, and also some of the land is reclaimed, which may be problematic.
MIT would pitch a major fit if you did any sort of digging around their hypersensitive labs as well.
I don't buy that MassDOT has zero interest in how the Downeaster makes it through MA en route to NYC beyond what it's going to cost them/us particularly considering that MassDOT has a tremendous interest in serving MA passengers and is almost certainly going to be more engaged in the routing process because of that. "We" / MassDOT / Massachusetts stands to gain something they wouldn't have otherwise from the Worcester-Lowell-Haverhill routing - I don't know how much value is actually tied up in potentially being able to move people across the 495 corridor that way, but it's at least worth looking at on a level beyond "this costs us more than that, forget it."
It doesn't matter if Mass Ave. gets some megaproject. The combination of the remaining the Broadway, Main, and Cambridge St. crossings still has car/ped/bike traffic LOS impacts too high to swing minimally viable 25 min. DMU headways either-direction. That's all laid out in that Worcester study's traffic counts. 4 or 5 TPH instead of 2 is still hugely far away from cutting it, especially with at least 4 hours of the day having 1 TPH vultured by non-DMU users.You're forgetting that there's two moving components here and we can adjust the elevation on either or both of them.
Mass Ave (as a state highway) can be permitted to experience a grade of as much as 8% - but we only need 4% and 400 feet of running room on either side to get it 16 feet under the tracks. If you're able to sustain a 2% grade over the 360 feet of running room on the Grand Junction, then you're already 7.2 feet above pavement and the Mass Ave 'dip' only needs 160 feet of running room at a 5.5% grade for the rest - or, just about the distance between the Grand Junction and the next crossing streets on either side. You wouldn't have to 'dip' the sidewalks either, because I don't believe the 16 ft. elevation would apply to them and a 320 foot pair of sidewalk bridges with 7.2 feet of clearance beneath the Grand Junction is the lesser of two evils compared to a 5.5% sidewalk grade.
I have no idea how much 640 feet of sidewalk bridge and 640 feet of 'dip' in Mass Ave. would cost... but it's surely less than the hilarious expense of a rail underpass here.
I went back and looked at a Fairmount-Red Connection more closely. Assuming that the Red Line rolling stock can handle 2% grade sustained over 1000 feet, there's more then enough wiggle room to sever Fairmount just north of the overpass at I-93 and get it underground without fouling up Widett/Cabot or the OC Lines, and once it's 20 feet underground there's a wealth of options for connecting to the Red Line south of Broadway even if I'm wrong about the track depth/platform positioning and therefore the junction I depicted isn't possible.
The Fairmount Red Line Conversion is probably a $1.5 billion project and 23.83% of that price tag is deliberate budget padding anticipating cost overruns.
Yes. They do have perpetual rights. Perpetual. Until CSX voluntarily files with the Surface Transportation Board to abandon their freight rights, they hold them forever. Even if they are never used...so long as CSX and any successor companies who inherit the rights are paying their fees it's theirs forever. For example, they never abandoned their Worcester Line rights east of Beacon Park even though it hasn't seen a freight move ever since the Boston Herald stopped getting newsprint deliveries. Despite allowing the T to clip their clearances at new Yawkey if they have good enough reason to run something down there and it can fit around that curved full-high and low Beacon St. bridge nobody can tell them no. That is how the interstate commerce laws work for railroads. It trumps local interests from bullying around a common-carrier national network, and the law compensates the RR's for the extreme regulation the gov't puts on them by giving them lifetime security on these rights.Whether that's the best use of $1.5 billion is besides the point. I don't consider $1.5 billion to be 'impossible' levels of expense. CSXT's perpetual rights to run over Fairmount (if they actually have perpetual rights to Fairmount and not just everything Franklin southwest of Readville) can be negotiated for, freight can still come into Boston and the Port of Southie via the Old Colony Lines - it works. It can be done.
Oh, I wasn't suggesting they didn't have an interest. But in terms of capital motivation for rehabbing the Grand Junction NYC-Portland doesn't even register when the first several years of it are unlikely to be more than 1 daily round trip. Operating on assumption that DMU's are a nonstarter, they'd be most intrigued by 1) dusting off the Worcester proposal for 5 round trips, 2) North Station Inland Regionals at +2 more round trips. Because those are pumping multiple round trips per day from Day 1. That's what'll move the $45M in funding to rehab the line.
So...it's not that they aren't interested in the revenue. I have no doubt they are. But it doesn't contribute in any way to the trigger for doing the upgrades. Not even in the "well, one more round trip helps" sense. The baseline go/no-go decision is all based on getting that commuter rail baseline and attracting just enough Amtrak/NEC interest to score a funding grant. There's most definitely other stuff they could come up with to run across it once they've got it, and NYC-Portland is an insta-add. But that stuff doesn't factor at all in the capital decision.
You can't get a useful DMU here. You can't eliminate enough of the crossings without spending at Urban Ring levels, and if spending at Urban Ring levels...spend for the Urban Ring. The costs will never wash on this mode. And there's no dancing around FRA regs on stuff like the gate timings to mitigate all the crossings as if they were a trolley stopping at a traffic light.
The thing is that the capacity over the Grand Junction is so low (and the impact of using it so relatively huge) that I don't believe they can just come up with other things to run across it whenever fancy strikes them after the capital decision is made.
As you've said yourself, there's at least three hugely-critical streets (I don't think Main and Broadway are both critical in the context of the other's existence and therefore you could screw up one - BUT ONLY ONE. If you agree, it's three critical streets; disagree, it's four) that get blocked for a non-trivial amount of time every single time a train rolls through on this thing. Part of the capital decision is going to have to be mitigating that and the agreement is almost certainly coming with a "you shall not ever run more than this number of trains through these grade crossings" clause attached to it. Until those grade crossings get separated (if ever), it's not going to be as easy as saying "well we've got this online for 5 Worcester-North CR roundtrips and 2 Amtrak Inland Regional-North roundtrips and they've all been popular, let's go ahead and add another round-trip or two or three..."
If we want the Downeaster to NYC running via the Grand Junction we are going to need to establish that before regular service begins, and we're probably locking ourselves into exactly one trip if we say that's what we want.
It's all politics, sure. But I'd be fascinated to find out how Maine feels about spending more money now to make the prospect of adding a second (or third or fourth) Downeaster to NYC later only a matter of negotiating for operating rights over freight trackage in the wilds of central MA instead of having to negotiate and mitigate with well-to-dos in Cambridge including MIT.
Maybe they decide it's worth it to them to sign up for having to do business with Cambridge! I don't know. But it's not as straightforward as 'Grand Junction open for revenue service now, worry about Downeaster later.'
I think we're crossing up our "TPH" terminologies, which maybe is my fault for not being clear.But... we've just spent the last several days going back and forth about how I don't believe 5 TPH is going to cut it on Fairmount and you've been yelling at me to stop trying to throw increasing amounts of money at the problem to get to the point where we can have more than 6 TPH through Fairmount.
The Grand Junction certainly has a lower demand than Fairmount - if 4 TPH (with an extra TPH vultured by Amtrak/Commuter Rail/Whoever) is good enough for them, why isn't it good enough if we can get to 4+1 TPH here?
See my last post on that. The problem is the blockers to eliminating any one crossing are in conflict with the blockers to eliminating any other crossing. And thus lowering the cap on traffic levels requires spending half an Urban Ring and flunking the value proposition for the DMU mode entirely. Mass Ave. I did outline has some options...but they aren't ones the T can take a lead on. And Main and Broadway have pretty stiff limitations in their own right, so frequency improvements per dollar spent on Mass Ave. are still pretty unsatisfactory as long as this is on a DMU. So, again, if this requires pouring most of the concrete and spending most of the cost for this segment of the Urban Ring, why are we still talking about DMU's instead of the Urban Ring?I don't know of anywhere that a combination raise/dip like what I suggested for Mass Ave has actually been done, but even assuming it's a $250 million project - none of the other grade crossings are state highways and therefore getting to 16 ft beneath the rails isn't necessary, making separating them a relatively straightforward case of simply dipping underneath the tracks with no elevating of the Grand Junction required. Unlike the combination raise/dip, I can point to multiple examples of dip-only grade separation. We can easily deal with Broadway and Cambridge Street this way and only Main Street might pose some difficulties - but even figuring $100 million (which might be seriously overbudgeting) for the two we can deal with easily and saying 'not worth costing out' for the one we can't, we're only up to $450 million. (Last I checked, the Urban Ring was priced at $2.4 billion or more than 5x the cost.)
Separating one of the grade crossings for $250 probably isn't worth it. Separating three of four for $450 probably is.
Not necessarily. The problem isn't lack of options for equipment swaps or freight, because the Pan Am Worcester Branch can do it. It's that it's going to take a lot of investment on a bunch of uncoordinated things that can't realistically happen all at once before they can reduce their dependency on the GJ and make Worcester viable. And because the revenue services run over the GJ are so niche-oriented around peaks where the subway transfers don't equal it on time, you do not necessarily have to build the Link to have any hope of replacing it. Just get the subways and transfer stations swallowing and distributing the crowds better like every study has been warning them to do or else. The only service that gets lost is NYC-Portland via Boston. And I wouldn't exactly consider that a must-have when stacked up against the Urban Ring.Of course, the real problem with spending the money on the real-deal Urban Ring is that the North-South Rail Link still doesn't exist - and as long as the Rail Link doesn't exist, the Grand Junction is a load-bearing critical piece of conventional rail infrastructure for rail operations in Boston, because the next best way to shuffle equipment between the south-side and the north-side is 100+ route-miles away.
So, even assuming that it costs the same to just get the Urban Ring operational, the real problem is that the Rail Link probably doesn't open until 2045 (at least) and until that happens, waiting for the Urban Ring is paying in both the actual cost of the project and a 30-year delayed start because necessary load-bearing infrastructure elsewhere in the city needs to be completed first.
I can't wrap brain around this logic. You want to pay for something twice over? Why not just build one thing once? Not only is that a waste of money, it's a waste of time spending all those years of planning for one mode only to have a do-over immediately follow. It's like the T's own UR phasing lunacy with BRT giving way to rail on dedicated ROW's overbuilt for busways when they'd be cheaper doing from Day 1 as LRT.Assuming 360 ft of 2% grade in two shots is doable by any and all non-DMU interests operating over the Grand Junction, it's probably worth paying once now to get 4+1 TPH in five years even though we might end up paying again in 30 years for the Urban Ring.
F-line, I have to disagree with your assumption of costs to trench the whole GJ. Why does it need to be cut and cover? An open cut would require no ventilation, and the only place there is any truly complicated construction is between Mass and Main due to abutters. Less than a third of a mile, everything else is pretty simple with plenty of room, especially between the BU Bridge and Mass Ave. This is a two track railroad, a 30' cut; not the big dig.
See above. You can't blast diesel fumes into the Red Line, and any construction on a common-carrier RR has to assume that any RR traffic (excepting Hazmat in a tunnel) could use it. Including long freight trains hauled by 3 lashed-up locomotives belching simultaneously. Nor can you have a new tunnel built that intentionally compromises the old such that a firey freight derailment in the RR tunnel puts everyone's lives in danger on the Red Line and forces its evacuation all the way to Alewife. That would never get approved in an EIS.As for undercutting the red line, that is the hardest part. However, its not impossible (the numbers to get that deep do work). You may not even have to get 50' down: a traditional underpinning of the tunnel structure may require it, however replacing the red line tunnel in that 30' section with a simple bridge, while it would require a weekend shutdown or two, is not beyond the realm of possibility, and would reduce the depth of the cut substantially.
See my last post. The demand isn't all-day for Worcester and Amtrak. ONLY the peak hours where the subway suffers under load. Otherwise the demand is always greatly higher to South Station, the Orange Line gets you to North Station from Back Bay in equal time off-peak, and the Red Line gets you from SS to Kendall in < 5 minutes of equal time off-peak. With improvements to the performance of those two lines like re-signaling for tighter headways decreasing the difference further.I agree with you that individual grade separation of each crossing is impossible and/or impractical. However, I disagree that trenching the entirety of the GJ would be as prohibitively expensive as you propose. A considerable expense, yes, but the ROI with the ability to throw half the Worcester trains, Amtrak through-routing, and a DMU line through there, in addition to eliminating the traffic jams from when an equipment transfer rolls through during rush hour outweighs it. (Hell, eliminating the traffic jams as they are now may be enough on their own if you add up all the lost time of every person sitting in traffic while a train rolls by, not to mention air pollution.) If/when the N/S link gets built (a BIG if), the ROW can be instantly converted to an urban ring line with minimal investment necessary. I don't see trenching the GJ as competing with the N/S link, but complimentary to it.
Regarding Amtrak and the GJ, if it were made a more viable passenger route, would it not make sense to combine the Downeaster (perhaps just the Portland south segment) and the Springfield shuttle? It's not quite the full inland route, but getting to New Haven gives you a million options to get to NYC, doesn't eat up slots through Metro North, and also gives Springfield a dandy connection to Boston (plus there is no required engine change, so equipment can stay separate).
---Upon further thought, if the GJ were made viable, I wonder if select trains from the northside could be routed out to Worcester or Framingham, allowing a one seat ride to Kendall and New Balance from Lowell, Newburyport, etc. This would be contingent on how fast they could turn a train at North Station.
I don't think the Great White BRT Hope is what we want to be replicating here with DMU over-hype. It's the same snake oil trying to sell a mode as something its not while privately acknowledging it's not and willfully going along with it anyway knowing it'll have a short shelf life and cost twice as much to do-over correctly for the service they're pitching. There's plenty of upside for DMU's and plenty of upside for BRT. Just not in every situation. This is one of those not-situations. Do it right or don't do it at all, because you're spending the same to do something whether it's right or half-assed.
