I agree you can say it better than talking about the gap.
But the gap means that North Side commuters headed to South and West employment centers probably drive. Same for South and West commuters headed to North Side employment centers. That is what is baked in: "you can't get there from here".
The "gap" talk obfuscates a lot of that, too. Because the next pivot is the pretty GIF diagram the Duke/Weld lobby used to have on their website of lines flowing through end-to-end.
Fitchburg-Greenbush! Cape-Haverhill! Providence-Lowell! Needham-Rockport! The magic of the one-seat ride ends up pwning its own message because it inevitably gets pitched as end-to-end, where the endpoints are nonsensical commutes no one makes and one's arse would go numb sitting in a CR seat while crossing 495 twice. The politician-crafted klunky talking points are unable to parse that with any relevance.
In the real world, somebody commuting from South Shore is S.O.L. at getting a job in the Waltham office parks because that's the furthest/most-painful car drive on 128 from where they intersect with the highways at Braintree Split. Now...change to Red at Braintree/Quincy Ctr./JFK and you've got an easy enough commute to Porter grabbable on 6-min. Braintree Branch frequencies. But who's going to carry two paper CR schedules around? Even if Waltham gets :15 Urban Rail frequencies and a 128 superstation with biz shuttle bus circulator to all the office parks the Old Colony's tri-branch schedules are inherently horrific for staging that many legs. Let's face it, even if you fix the Dorchester pinch there's still too many mouths to feed that neither Greenbush nor Plymouth nor Middleboro is individually going to run at brisker than :30 schedules. Either move, or that commute is just never going to be practical to do car-free.
What changes with NSRL is a double-whammy. You'll have the run-thru slots to chop a couple seats off that multi-transfer train + subway + shuttle bus trip. It'll even make it easier to take
your own local bus to the 495-land CR station instead of Pn'R-ing because not having to do the Red Line interlude makes another bus leg tolerable. But more than that, the doubling of terminal district capacity with the upstairs/downstairs filet is what lifts the frequency cap from having to make do with an Old Colony that splits the tri-branches :30/:30/:30. They can be packed denser...running headlight-to-taillight on a double-track main such that you can elbow-grease the Brockton, Weymouth/Abington, Hingham, etc. inner-halves to :15 on top and never again have to carry the paper schedule even for the half-hour chunking. And the multidude of gained frequencies means you also don't have to care much whether the given train you board is fileted to tunnel run-thru or surface-terminus, much less whether it's running thru to the
particular South Shore branch you ride. Count 'em up...how many opportunities en route do have to hop on/off at one platform to correct the destination? It'll be like taking an any-Red Line train and doing the Broadway/Andrew hop from a Braintree to an Ashmont or vice versa to set your destination...something commuters do unconsciously all the time. Only with this RUR-revolutionized...
then NSRL-revolutionized Purple Line...you're making the same unconscious hop only with
multitudes of possible destination signs to pick from. So even the multi-seat trips are a whole lot easier, as they require way less huffing and puffing between platform levels to chart a course.
^That^ all is the brain-exploding promise to the average commuter. No paper schedules because the system throughput is so much higher (i.e. why not to confuse tunnel as replacement for surface terminals when the service ceiling is achieved by playing both off each other). Set-it/forget-it transfers on a single platform hop as byproduct of the frequency and variety of frequencies, instead of having to exert physical energy to hit a transfer. Linked trips that do away with time-chewing middle transfer legs
so that there's more bandwidth for outer transfer legs, and net higher car-free mode shares (i.e. it is
not about promoting the one-seat at all, but by lowering the
bandwidth of linked trips so practical options are exponentially greater). And in turn that keeps the options diverse while the actual ops of the tunnel is not going to equally represent "everywhere to everywhere" like the simplistic Duke/Weld website said. Tunnel pairs have to be tolerably schedule-balanced, prioritized to the highest-priority trunk pairings, and given consistent enough churn on the highest-priority trunk pairs that niche or alt pairings simply aren't going to have many turns at one-seat frequencies (and will be directed to the surface when they don't meet certain basic balancing-act standards). Rather, sheer escalation in frequencies of every kind + 'right enough' regular churn of max-priority thru-slot rotations serves up destination variety of the whole smorgasboard of the system with similar 'brainless' one-hop ease as making the Ashmont/Braintree hop that's second-nature at a Broadway or Andrew. Including when it's a hop between a regularly-repeating trunk slot and a niche slot. Niche slots can even include otherwise marginal prospects like "Lowell/Nashua via Salem St. & Tewksbury on the Wildcat Branch and Lowell Branch instead of North Billerica" or "Attleboro via Norwood/Walpole and Foxboro on the Franklin Line + Framingham Secondary instead of Providence Line" every hour at peak, 90 minutes off-peak...stuff that would be waaaaaaay too marginal as one-seat alt patterns but where the higher-caliber service blender of the supersized system provides the farebox recovery via enabling such easy/brainless one-hop transfers.
It's all rooted very thoroughly in "It's the frequencies, stupid!" leading into "Frequency creates new mobility". Benefits of run-thru are explainable at their most dynamic, speaking directly to
the individual voter's own commute by running through that pipe. "Gap"-centric talk doesn't have any record of success doing the same...because it doesn't explain where behavior changes or is conditioned to change because things got
way easier for the commuter. Instead the pols end up backfilling it with abstract theatre like "everywhere-to-everywhere" in some flat-world overrating of the one-seat, where you already know there aren't infinite enough combinations of one-seats to change ease-of-commute behavior for a wide enough spread of destinations (see also: the SEPTA fallacy, as if an all-world shitty frequency run-thru system is what we aspire to). But level the bandwidth sucked up by linked trips
in addition to facilitating a nice core slate of high-demand one-seats? Fuck yeah, that's revolutionary in a way anyone actually trying to make a trip within daily allotment of time & energy can immediately grasp.
We unfortunately may have to wait until the "gap" generation of politicians and their copycats are all dead before we can impart the frequency-rooted talking points sans interference. Especially since mere retirement and civic obsolescence is proving to be no deterrent from Duke/Salvucci et al. continuing to pollute the NSRL word salad with that dead-end liner.
