Joel N. Weber II
- Aug 30, 2015
That 400kWh of battery pack takes up about 90 cubic feet (when estimating based on Model S pack size; using the larger model 3 cells and changing the overall shape might reduce the size). http://www.evwest.com/catalog/product_info.php?products_id=476 lists one Tesla Model S motor at about 5.9 cubic feet, so 4 Tesla motors might be somewhere around 23.6 cubic feet. (It would be ideal to find Model 3 numbers instead of Model S numbers, but those numbers seem to be harder to come by.) Also, that photograph suggests that the motor is not exactly rectangular, so maybe if it fits inside a rectangular box roughly 5.9 cubic feet its actual volume might be even smaller.
Also, you might not need the full 90 cubic feet / 400 kWh of batteries per axle; the comment on Alon Levy's blog post claimed 1.1 megawatt hour is needed for a Providence to Boston trip for a 320 ton train, and if that train consists of four 80 ton cars, each of the 16 axles on the train only needs about 69 kWh of batteries connected. There's also the question of whether you get adequate acceleration, but it looks like the 300 mile range Tesla Semi may accelerate just as well as the 500 mile range version, and if 2 MPH/s is good enough for Metro North it might be good enough for a minimal battery powered train too; if the 800kWh estimate for the 500 mile range Tesla Semi turns out to be accurate, then 160kWh per axle might provide enough batteries to achieve 2 MPH/s. (And that assumes each Kawasaki bilevel car with batteries added would weigh 160,000 pounds; since they'd actually weigh a bit less, the battery packs could probably be downsized a bit further. Also, if the goal is reduced to 2 MPH/s, downsizing to three Tesla Model 3 motors per truck instead of four ought to work, and perhaps some trucks could even get only two Tesla Model 3 motors.)
If you look at the gasoline engine in a 1960s Chevy sedan, can you conclude that a smaller gasoline engine could not possibly work in a 2018 Toyota Camry?
