WormtownNative
- Dec 7, 2014
Re: North-South Rail Link
NJ Transit uses dual mode loco's on lines where they run on overhead catenary on their "main" lines, and switch to diesel power when they get to the branch lines where the catenary lines don't exist. It would solve the problem of not having to electrify the entire commuter rail network quite nicely, or at least provide a solution to buy the commuter rail network the years needed to electrify everything.
That said, these dual modes cost more than your typical diesel powered or catenary powered locomotive, so it might be better just to bite the bullet and start a full changeover.
(For a video of the changeover of the overhead to diesel:
https://youtu.be/dUI19vdvSOU)
Please correct me if I'm wrong, but doesn't the electrification requirement also mean that large stretches of the existing commuter rail network would also need to be electrified to take full advantage of NSRL? I used to live next to the Haverhill line, for example, and that definitely wasn't electrified. I am making this assumption based on locomotive usage...
But then again perhaps there are diesel/electric convertibles that could share mixed electrified/non-electrified track networks? If the latter, then is it reasonable to do locomotive fleet replacements along a timescale compatible with NSRL completion?
Thanks!
