I thought I wasn't permitted to dream that the Gateway would be extended (though I can't remember why I think that).
Beacham is cheap (and un-congested for now), but isn't there plenty of room on the railroad ROW right around to Wynn's (and Costco's) back door?
I'd like to see a Gold Ring (both clockwise and counter-clockwise):
Airport-Gateway-Wynn-Rt99-Haymarket-Callahan-Airport
There's plenty of room, but you have to switch sides of the ROW from south side to north side at 2nd because of the Everett Terminal freight spur. On BRT that means big honking flyover ramps that'll cost just as much individually as this whole Gateway build to Chelsea, and draw the ire of all the residents on Paris St. who'd have buses on a high ramp looking into their rear windows. Can't cross the RR tracks at a blind at-grade angle; that's a doubleplusbad idea. Can't go underneath in a duck-under on BRT because of an underground stream...only with trolleys where the inclines can be hella steep like the Wellington tunnel to compact it away from the underground stream. As long as this ROW is BRT-compatible, it has to be flyovers.
No amount of Wynn fun bux would cover that expense, and it's not an expense the state would consider only for an Everett extension. That's a real-deal Urban Ring commitment where you're building the flyovers in tandem with the Mystic River crossing to make the utilization worth the cost of the construction. So we're not going to see any further grade-separated busway extensions in the SL Gateway configuration...only for the UR.
Hence, take advantage of Beacham and any allowable bypass around the back access road of the Mall that shaves a couple traffic lights off the trip.
