How many times do we have to keep posting this exact same diagram? Clearly the 480' is the same bs we always get, to the "highest occupiable floor" which doesn't even include the ceiling of that level, let alone the mech above. It's probably about 530' to the top since it's built on a hill and tough to tell where the bottom measurement would be taken from.
Then to make it relevant to the fact this is the State Street specific thread...
The CTBUH says 519 ft.
They took the diagram I posted above literally, subtracting the 27.52 base away from the 547.33 top to get 519.81. As we continue to hammer home, nobody is sure if the 27.52 is the absolute lowest level of the base, or if it slopes down further on one of the sides. It's a slightly unclear diagram in that respect. Official height measures from the lowest point to the highest point, and the lowest point isn't clear here. We know it's a MINIMUM of 519.81' but could very well be higher.
While we are on the subject of height, is there a final accurate figure for Bullfinch One Congress, both to the top of the actual building structure as well as to the top of the higher fin? Sorry if this has already been discussed but too lazy to go through the hundreds if not thousands of prior posts. Thanks.
“Slap a State Street sign on her, and you’ve got your girl” 💀
So... with the floating cranes, how do they disassemble those? Usually the crane slowly disassembles itself back to the point where a smaller crane can then handle the rest of the disassembling work and put the cab and few remaining tower pieces on a truck.
My only thought is helicopter?
325 Main St in Cambridge assembled a derrick on the roof to disassemble its tower crane.
