- Jan 7, 2012
Re: 600 Harrison | 600 Harrison Ave | South End
https://flic.kr/p/BRHJft
https://flic.kr/p/CLNeGm
https://flic.kr/p/CmYL9w
Looks like they are using a different building technique. Instead of rising fast using poured concrete and then working on the inside for a year it looks like they are working on each floor as they go. Should take as long, maybe actually shorter. Just feels longer because it hasn't topped out yet.
Can someone (with construction/engineering background) provide some insight on why they're using this technique?
They have to go floor-by-floor because the steel stud walls are the structure that holds up the metal deck. Notice the absence of steel beams on the upper levels. Beams require expensive custom manufacturing & installation compared to steel studs that can be installed by your uncle.
The density looks pretty good. Only thing is i wish they could build indents with changing roof heights and cladding to give it a row-house look. For that matter i wish the exterior looked at least up to faux row-house standard as they're doing in the Fenway. Looks like Arlington, TX.
Staggered windows .... check
Randomly alternating colored panels.... check
