- Jan 7, 2012
The Batterymarch building does this trick where it uses darker colored bricks on the bottom, and subtly becomes lighter as it goes up. It produces the effect of making it seem taller and gives it more vertical thrust.
I'd love to see someone try the same trick with these terra cotta blocks.
Having posted this, I just noticed how much the Mandarin on Boylston takes from the Batterymarch. Never noticed it before.
This building is the definition of class, incredible addition to the seaport.
A roundabout way of making their buildings looks shorter so as to avoid NIMBY wrath?
Ding ding. The Colossal Order simply makes buildings appear shorter.
I look forward to voting for this project as a shoe-in for Best of 2013.
Cannot praise this development enough. It does exactly what it needs to, it takes cues from the surrounding area and using them throughout, its the perfect height for the area, it stands above the buildings around it and also creates the step up from south boston to the boston skyline, its built with quality materials, it even has an above ground garage that seamlessly blends in and looks like it was not an afterthought which is very rare, found a way to add balconies and not look cheesy, and its looks old but also has modern design elements. This thing is an A+ for Boston and this is exactly what we hope for every time something new gets built, but it somehow seems like nothing ever lives up to expectations. This building lived up to them and also surpassed them. Hopefully other developers will look to this and realize that you can have a quality development without having to go over the top, it just takes quality materials, a sense of scale and symmetry, and not being afraid to do something different while still not being over the top. The only negative I can even think of is that it would have been even better if it was taller, but this is the seaport and even as is it is a good height.
Well done but should have been at least 5 floors taller. Tired of the double height window sectioning here and in many others. They really can dilute the sense of verticality.
Brad, I fully agree. I'm not fond of this "Collossal Order" style (The new Brutalism?). We see alot of long, wide landscrapers, and the ones that threaten verticality are cooled off with double height windows. The Exeter tower (which could have been a strikingly tall building) is one example. I rarely see that in Manhattan or Chicago. It is as if Calvinist Boston is embarrassed by tall buildings and wants them to look less imposing.
