underground
- Jun 20, 2007
Breaking News: LI Residents in uproar over imagined problems with imagined project.
Just wait till the first Westchester County presentation.
They've been uproaring nonstop over imagined problems with real projects with immediate benefits, like re-laying Main Line Track 2 to Ronkonkoma and Track 3 to Hicksville. LI NIMBY's vs. a wholly imaginary project is like handing out speedballs at the door and seeing who can concern-freebase the fastest.
Alt 2 should go via Worcester and electrification should be extended to Upstate NY and Interior New England...
I would agree with you, but that involves building a lot more track through very bad terrain. 2 only requires a new run between providence and hartford.
^ So have I understood your plan to be to build the Hartford-Providence on the I-684 alignment and then serve Worcester via an improved P&W? Would you see then see the new NEC spine running HFD-PVD-RTE-BOS or PVD-WOR-BOS?
Could a single line that ran NYC-NHV-HFD-PVD-WOR-BOS be fast enough? Maybe? basically it'd be doing a 90deg turn at each big city but have potentially very straight-and-fast running between each?
It'd be pretty amazing to tie every major city in New England to each other in a network this way (with SPG as a tag north from HFD...SPG-HFD-PVD-RTE-BOS would be a pretty sweet market (on the existing 165mph stretch too)
We build things through complicated terrains all the time in this country when we decide to spend a lot on infrastructure. We've currently decided not to, which yes, presents a problem generally and for a Worcester inland route specifically.
