Re: The Boston Arch (Aquarium parking garage)
It doesn't look too bad that way. However, we already have two near identical buildings, one shorter, one taller, just down the street at Int'll place. I don't know if that same scheme will work just a short distance away.
If they can't do the arch, then they need to completely overhaul it (they can't do the arch if it's only going to be the same height as many of the nearby buildings). Hacking up the original design is just that... a hack job. The arch was great when it was the arch; without it, it's two similarly styled buildings of different heights, just like IP.
Furthermore, those two buildings without the arch are just boxes that are the same height as nearby buildings. If it's going to be the same height (actually, about 10 feet taller than the next highest in that area), a spire (they don't count in the "height" stats, do they?) and tapered design could at least detract from the stump effect a little bit.
did a quick edit job in paint i think it looks amazing without the arch
