- Jan 22, 2012
It's on the future Urban Ring route - which will be GL in all likelihood. Potentially this could jump start that project.
I got this question in at the end of a page a couple back, so I feel justified bumping it given these transit comments...
Actually, unless they've re-aligned the ring since 2010 (and I know there's been talk) the 2010 alignment misses the Wynn Site because the Urban Ring was designed to hit Sullivan, Assembly, and Wellington (the fat yellow line in the Northwest corner) before coming back to Everett.It's on the future Urban Ring route - which will be GL in all likelihood. Potentially this could jump start that project.
It is marked on this Aerial View in Bing of 42.393925,-71.071722 (Bing zooms you out, so please zoom in) and worth a some "flying around" because there are a lot of problems in 3D.The Everett site is located right next to the commuter rail line to Chelsea, correct?
EVERETT:
- Where the hell is Everett and how do you get there?
Between the water needing to be passable, the locks needing high clearance, the bridge being humped, and Wynn being to the east of all 3 and Assembly being west of all 3, you have a lot to deal with to connect any to any there.
Which is why the Earhart dam looks easy to cross/connect but it hasn't been, and part of the reason why the Urban Ring had chosen to "around" rather than "through" this area.
Let's review the Transportation options for Wynn:
0) Do nothing. The reality is cleaning up the brownfield and creating union jobs is such an attractive package that nobody needs to offer anybody any transit spiffs anywhere.
1) Commuter Rail Station (behind Costco/Home Depot in Everett).
Pro: right on the site's edge
Con: Bad grade coming off the bridge,
Con: low frequency of service (Newburyport/Rockport line)
2) Spur from someplace:
Pro: purports a direct connection
Con: Even if Wynn paid for a station, nobody would want to see "their" trains diverted to it. Not gonna happen.
3) Pedestrian connection from Assembly, over A.E. Dam, under Rockport Line to Wynn's waterfront.
Pro: Lots of great connectivity (Assembly-Costco-Wynn)...makes a connection that today takes both a car *and* a circuitous routing
(If I owned the Target/Costco shopping center, I'd push for this and TOD on my riverfront "back lot" and tout the short walk to the Assembly station)
Con: A long hike for Wynn patrons and too many non-Casino non-glamorous users, so he's not going to like it.
4) Aerial/Cable Gondola
Pro: Flys from Assembly, over river, dam, and railroad, straight to Wynn. Solves all the thorny over/under egress problems at ground and water level.
(If I were Wynn, this would be my preferred option because its nearly-exclusive and straight from Orange Line to the Slot Machines)
Con: No public benefit
5) Divert the Urban Ring. Convince MBTA to cut Assembly & Wellington from the ring and run from Sullivan, up Rt 99 and rejoin the exclusive (former railroad ROW) busway in Everett (just before the Rotary with Rt 16)
Pro: Urban ring finally gets a reason and a sponsor
Con: Cuts off a lot of TOD users with 'real life' trips at both Assembly and Wellington in favor of just Wynn's workers (and a future "revitalized" 99?)
I'm confused. "Routed along" seems to involve either a new bridge or severing the Rockport line. Either way, Wynn may have $50m to throw at neighborhood improvements, but not the $500m that your "spur" will end up costing.I'm confused. Assuming the RoW for the commuter rail is wide enough, why couldn't any green or orange line tracks just be routed along the CR bridge thats already there?
Option 2 - the rapid transit spur - still seems like the best and easiest. True diverting the OL would reduce headways towards Malden, but the GL wouldn't have as much of an issue. Plus it could cross at grade to extend into Chelsea and complete the UR segment to the airport. I see little downside here, even for Wynn.
I'm conflicted., but Everett is totally with you on putting a CR station right there behind Home Depot in this late 2012 redevelopment plan:But I can definitely see how such a project could rapidly add up in $. What are your thoughts on simply building a future-proofed Commuter Rail station for the casino, other than the physical problem of the grade and ridership?
The problem is that there isn't anything nearby to connect... Anyway, an aerial gondola would still allow for the redevelopment of the immediate area on Rt 99.
https://maps.google.com/maps/ms?msi...&ll=42.390185,-71.07296&spn=0.027988,0.066047
Also, if successful, it might show that aerial trams are a viable means of relatively inexpensive short spurs from T stops, which could be used in other parts of the city (e.g. Navy Yard -> North Station, Logan Airport -> Blue Line, Wood Island -> somewhere in Chelsea, UMB -> JFK).
The Wynn site fronts onto Route 99 and backs unto the Purple Line (and Costco and Target, beyond)
Only if the Urban Ring was "short cut" up Rt 99 would it touch the Wynn Site. Open the detailed view by clicking this preview![]()
But the UR isn't railed, and even those circumferential trips, if counter-clockwise, would prefer to join the Orange line at Wellington, and if Counter-clockwise would prefer to join the Orange line at Sullivan. In the end, I'd expect them to add at least 1 bus stop between each rail station they serve (like a "Ten Hills / Assembly North" or a "Station Landing West")The UR will likely have to follow the Eastern Route out of Sullivan. No point in a railed UR stopping at Wellington when Sullivan has an OL transfer as well.
Not really, the Wynn site is really just along "lower" stretch of the purple, just as it straightens (not much farther north than Assembly Square's station) while the proposed UR station is pretty far north --about 6/10 of a mile--snuggled just below Route 16{Edit}.Either way, even that map from 2010 has the UR joining the Eastern Route at the northern side of the Wynn casino site.
Not really, the Wynn site is really just along "lower" stretch of the purple, just as it straightens, while the proposed UR station is pretty far north --about 6/10 of a mile--snuggled just below Route 99.
Sorry to disappoint, but guys like Wynn don't kick-start transit billion dollar transit projects. Hosting the Olympics, maybe. But you don't get to be a billionaire by spiffing the locals down payments on transit empires.The 2nd Phase UR that you posted is bussed. The ultimate plan for the Urban Ring is an LRV main route working in tandem with "BRT" stretches.
If anything, Wynn's money could potentially kick-start the T into forgetting about the wasteful BRT "transition phase".
Yes, Rte. 16, sorry (fixed it in the post).You mean Rte. 16? Ok, I was unaware that Wynn's site was only below Beacham St. All those industrial site in Everett are hard to separate. Of course, with the number of old rail stubs that run through that area, a railed Urban Ring could swing through the site closer to the site and rejoin the Eastern Route somewhere around 2nd St.
You just don't. Heck, even in Las Vegas itself, they couldn't/wouldn't get the Monorail all the way to the airport (and were happy to fob most of the cost off on outsiders whom they bankrupted).
