Re: Dr. Beverly Scott resigns
God damn it.
This situation begs the question - if...
God damn it.
After noting that wind and gravity are huge helps clearing bridges (Longfellow), viaducts (Lechmere) and Els (1978's Orange) I am thinking that this must be atleast part of Chicago's secret: near 90% tunnel or El (including berms) maybe 9% surface, and near 0% trenched.
Would you say then it would be a worthwhile investment to switch to pantograph on the RL & OL outdoor portions? Is this something that CNR could theoretically implement in the new order or would a substantial redesign be required?The entire Blue Line and the Riverside D-Line were in operation today. The MBTA was conservative and stated Sunday night that Blue would only run from Airport to Bowdoin and D-line would be bus, but in fact train service was operating on both from the start of service Monday. Both lines operate on long surface sections. Unlike the surface Red and Orange line however, both lines use overhead wire on the surface and not third-rail. In fact, I would guess the MBTA was conservative about what they could run Sunday night in case the high winds caused wire damage, but that did not happen.
The private right-of-way of the D-line actually helps it compared to B, C, and E, as it avoids the problem of plowed snow from roadway plows blocking the lines at intersections.
I guess on the flipside too, the D branch doesn't fare too well in hurricanes when trees take down the wires.
Are the trains running with specific destination signs? Could be some good opportunities to get some rare pictures! Sullivan, Back Bay, Andrew, Kenmore.
I mean, hey, there has to be at least one upside to all this, right?
I guess on the flipside too, the D branch doesn't fair too well in hurricanes when trees take down the wires.
They got a heat-blowing machine to do that with. I've seen it in use on the news.
Why aren't they using it? Wouldn't that help save some time & hard labor?!! But not to THEM. That would make some sense.
I'm sure Winston knows more about this, but you can't run a train of any kind on the Red or Orange lines when the third rail is covered with snow. When the T abandoned the above ground portion of those lines during last Monday's storm, they allowed drifts several feet in depth to collect on those rails.
Even if the T had a heat blaster ready to go, they simply can't propel it. Incidentally, I think the reason the D can run today is because catenary wires don't have this problem. Not sure why surface Blue is still a no go.
That is why you usually use a diesel locomotive to drive the blower. No need for the 3rd rail.
^ Blue Line is fine. It ran the full route yesterday and will today.
I had read that it was truncated at Airport. Good to know.
