One Post Office Square Makeover and Expansion | Financial District
DZH22
The top of this is weird. Should have been a crown of some sort, adding a few feet. Instead I think it might be slightly shorter than before, 516' vs the previously listed 525'. But really, what were they thinking with this?
IMG_8962 by David Z, on Flickr
BeeLine
Moderator
Staff member
stefal
I'm struggling to imagine how the interior is going to work with this. Are they just going to be very deep window wells with drywall/trim extending from the existing interior wall across the existing window well to the new curtain wall? Is the existing exterior envelope that inefficient that this is still feasible through heating and cooling cost savings? I don't see the point of going through all the trouble here if you're getting the same amount of light in the space..
Life Coach Mike
It appears from the pics that the struts holding up the new curtain wall are attached to the structural framework and that the concrete panels, and thus the old window openings, will be removed as the work progress, increasing the light/space.
stefal
So why not just remove them now like they did on the bottom levels?
bigpicture7
Check out Posts #619 - 625 of this thread for answer/discussion on this
From info available in the PNF and tower design itself:
1) Upper floors remained tenant-occupied during this renovation
2) Some of the upper floors actually had substantively larger windows to begin with than the lower floors; something I never noticed previously, but that is clear here.
rjacobs
6/3 from Mount Auburn
IMG_0160 by David Z, on Flickr
IMG_0212 by David Z, on Flickr
IMG_0240 by David Z, on Flickr
DZH22: Do you happen to have older photos from the same vantage point/location, prior to the recladding? That might settle whether or not an additional level (mechanical) was added at the top. The tip of the lower One International Building makes for an excellent 'marker'.
DZH22
Didn't think this would be the case, but now that I pull up this older pic it actually looks like it might have gotten taller.
IMG_7339 by David Z, on Flickr
